Thane Heins Perepiteia.
JustMe
Quote from: LarryC on April 05, 2008, 03:34:21 PM
Okay, I'm not going to go wacko yet. Having a hard time making out the decimal place on the ampmeter.
If .01 then .035W out and .019W in. If so, how much for the big honking 5000 watt version?
Regards,
Larry
OilBarren
OilBarren
Quote from: JustMe on April 05, 2008, 02:20:36 PM
Could somebody jot down how efficiencies can be calculated from this data?
EFFICIENCY% = Output voltage(squared) divided by1000 divided by Input Power X 100
                       = V^2 / 1000 / Pin X 100
EXAMPLE: CONVENTIONAL TOROIDIAL TRANSFORMER
Vout = 92.2 V
Pin = 9 W
EFFICIENCY% = 92.2 x 92.2 / 1000 / 9 W x 100
                                = 94.5%
Thane
polarbreeze
The formulas are in the attached spreadsheet. The new data yields:
EI core transformer = 68%
Conventional toroid = 95%
Potential Difference bi-toroid = 38%
PB
OilBarren
Okay, I'm not going to go wacko yet. Having a hard time making out the decimal place on the ampmeter. If .01 then .035W out and .019W in. If so, how much for the big honking 5000 watt version?
Regards,
Larry
FORGET IT LARRY - AT LEAST UNTIL WE FIND OUT WHAT THE POWER FACTOR IS IN THIS CASE - OUR POWER POWER FACTOR METER DOES NOT MEASURE THAT LOW - ALSO WE REQUIRE MORE TURNS AND HAVE RUN OUT OF WIRE. OUR NEXT POST SHOULD BE OSCILLOSCOPE READINGS.
Thane
