Thane Heins Perepiteia.
vince
@PerpetualLurker
Post #192.
OilBarren
Quote from: Mr.Entropy on April 07, 2008, 03:33:54 PM
Thane,
We know that connecting the load coil makes your motor accelerate.
It is possible that the coils' cores simply introduce a loss that is being reduced when you connect the coils.  In that case your motor will accelerate more if you simply remove the whole coil/core assembly and put it a few feet away.
Does your setup permit you to perform this test?
DEAR MR. ENTROPY,
WHAT YOU ARE REFERRING TO IS AN EDDY CURRENT BRAKE AND HYSTERISIS BRAKE - NEITHER OF WHICH CAUSE ACCELERATION.
AND YES OF COURSE THE MOTOR WILL ACCELERATE MORE IF THE COILS & CORES ARE REMOVED BUT THEN YOU WOULDN'T HAVE A GENERATOR EITHER.
FOR ADDITIONAL INFO:
Comparison information on eddy current brakes and hysteresis braking operation
http://www.eng-tips.com/viewthread.cfm?qid=135753&page=9
LUC IS WORKING ON A DESIGN WHERE THE COILS WILL BE GRADUALLY BROUGHT CLOSER TO THE MAGNETIC ROTOR - TO DETERMINE THE IDEAL AIR GAP DISTANCE FOR EACH COIL USED.
Thane
OilBarren
Quote from: PerpetualLurker on April 07, 2008, 07:11:21 PM
OilBarren:
I have looked through previous posts in this thread for some kind of schematic diagram of your bi-toroid transformer setup.  I found something way back in message #244 (though I could have missed something more recent) which shows a primary winding and two secondaries, both with loads.  In the recent photos and posted results I can only see references to a load and measurements on one secondary.  Can you shed some light on how the other secondary is connected?
ESSENTIALLY THE TWO SECONDARIES ARE WIRED IN SERIES WITH ONE DANGLER COIL.
Thane
vibrovirii
n00b question here  ;D
My coil attrachts instead of pushing the magnets away. Any clue what I did wrong?
I got neo magnets adoesn't matter if i face all N or S of the magnets to the coil.
Made my 1st simple coil with a ferrite core.
If it's not the place to ask here, let me know ;)
Peace, V
polarbreeze
Quote from: OilBarren on April 07, 2008, 09:01:34 PM
Thane
They do when you "release" them slightly, which is what's happening when you cut in the other coil (in the green-coil-gold-coil thing for example).
PB
