Thane Heins Perepiteia.
0 Members and 69 Guests are viewing this topic.
aether22
I got more wire, I thought I mentioned that on here but maybe I only mentioned it in a private email or 2.
I used a solid 1 inch diameter steel rod as Thane initially used, no laminations to remove, i could try drowning it in CRC/WD-40 or soap and water (but do not want to encourage rust) but I think cutting it is going to be the easiest solution.
Now I'm just putting off a big clean up of the garage I will need to do to regain some space before i can proceed, but I should have absolutely everything now besides of course the space.
Though I have not tested my Tach yet which consists of an IR led, a small led looking thing which is in fact a photo-transistor sensitive to the light from the former and a multimeter.
LarryC
Quote from: aether22 on May 07, 2008, 06:45:13 PM
Okay, I ended up using the 1/8 thick steel pieces from Home Depot in various size to match the cups.
Let me know how your tach works out. I am using a bicycle pedometer (under $20), which is very  accurate at lower speeds, but when you get above 1000 the rpm range starts to jump. At 1500 the jump is about 15 rpms. Lately I've been reading about model airplane propeller optical tachs that are very good at higher speeds for around $20.
Regards,
Larry
aether22
Oh, good info, thanks Larry!
note: actually too many turns isn't a real concern because due to the breakages I have the following ohm choices: 30, 120, 150, 450, 480, 600 all rounded slightly (smaller numbers happen to be closer to the core and ohm for ohm represent a greater number of turns)
i_ron
Quote from: OilBarren on May 06, 2008, 11:02:19 PM
A PICTURE IS WORTH A THOUSAND CONFESSIONS.
AND IT MIGHT HELP OTHERS AS WELL.
Thane
Here is a re-enactment, not all bolts in place and only one magnet in the pocket...ron
i_ron
THIS ENTIRE THREAD IS ABOUT LENZLESS OPERATION - OR DID YOU SLEEP THROUGH THAT CLASS?
Thane
Here on the coast we take anything that comes out of Ottawa with a grain of salt,
thanks for the wake up call, LOL
Ron
