Thane Heins Perepiteia.
LarryC
Quote from: OUman on May 11, 2008, 03:03:17 PM
Quote from: adlep on May 11, 2008, 10:36:10 AM
U keep changing your story. Do not blame me for your own words:
"Whoa Cool " says Larry - you paid only $122.30 for 130 oranges.
They were not my words - they were Larry's words. Check the posts.
I'm sorry, OUman, but you seem to have become completely delusional. Really sad! I never used fruit in this argument, just you and your little Jimmy pal! I think you should immediately report to the spook help line for treatment and retraining.
Best of luck,
Larry
mackensteff
Thanks for the response.  I know I might come off as a PB or OUman, but believe me I am hoping this works out.  I remember as a child probably about 12 realizing that there is a finite amount of oil for us to use, and as a chemist that is our supply of starting material as well, and if it goes a lot of materials that we have come to rely on will also go.  I lived in England for two years and was exposed to gas at least twice what it is in the states and actually think the gas prices are good, not for the pocket book, but to get people to finally realize that oil is a non replaceable natural resource that needs better management.  Anyway I am impressed with Thanes dedication and passion for the project and promise my questions are for my edification and not fault finding and appreciate the time spent by other educating and sharing knowledge.  Like I readily admit I am a newbie in more than one way as my exposure to electo/magnestism was a college physics class.  Another question for Thane to quench my interest:  have you had any personal evidence/experiences that correlate directly to big oil trying to hinder your work (other than a few spooks on the forum)  I have heard all the conspiracy theories about big oil buying up tech to avoid it coming to market, and since you are so open I thought I would see if you have seen anything personally.  Thanks for the patience and now school is over I am hoping to pick up the physics text and try  to get a better grasp on what is being talked about.
LarryC
Quote from: mackensteff on May 11, 2008, 03:34:47 PM
If this generator is operating under nonstandard conditions and produces a lot of heat, when the coils are shorted and the system speeds up or less watts are supplied to keep the same rpm, how do you know less heat is not being produced and the effect is simply not making the generator more efficient, and producing less heat?  If it is making the generator more efficient under these nonstandard conditions, it this setup still useful since so much energy is being lost as heat.  I find it fascinating the generator speeds up, but truly how 'efficient' is this set up?  Thanks for allowing me to play.
Hi mackensteff,
Just want to clear up one miss interpretation implied by your NONSTANDARD CONDITIONS statement . The high speed test are obviously done under standard conditions as the unloaded rpm would not have been so close to the theoretical max rpm of the motor if standard power was not used.
Yes, we all love to play with those who believe in discovering the truth.
Regards,
Larry
aether22
Hello,
First time poster.  Background: I got to here from following Steron, and have been following this thread from essentially day one.  I am a chemist by training, but have long realized the need for alternative energy sources.  I'll will admit readily most of this is far over my head, but I am trying to learn.  I know this will sound like I am siding with OUman and that is last thing I want as I see the same formula used by it as by PB, meaning change the argument to stir the pot, which is not what I want to do.  I really want to understand and could someone help correct my thinking here:  If this generator is operating under nonstandard conditions and produces a lot of heat, when the coils are shorted and the system speeds up or less watts are supplied to keep the same rpm, how do you know less heat is not being produced and the effect is simply not making the generator more efficient, and producing less heat?  If it is making the generator more efficient under these nonstandard conditions, it this setup still useful since so much energy is being lost as heat.  I find it fascinating the generator speeds up, but truly how 'efficient' is this set up?  Thanks for allowing me to play.
Q: "how do you know less heat is not being produced and the effect is simply not making the generator more efficient, and producing less heat?"
Good question.
Well you don't, and if this was merely a motor generator that accelerated when the secondaries were shorted far fewer people would be interested including me because it could very well be some mundane effect. (and would likely be assumed to be such)
But to many of us one single experiment sets this apart, it is an experiment that has not been explained, that is of course the initial experiment where the difference between a steel or brass coupling between the generator and motor makes all the difference, and that is a very very worthwhile anomoly!
Because further tests put the nail in the coffin that magnetic flux is what is conveyed through the shaft then any hope of a conventional mundane answer is gone, indeed the only explanation I am aware that even exists is my own aether theory, one that explains primarily what is transferred if not how it then effect the motor, indeed it is possible (if unlikely) that the effect on the motor efficiency conveyed by the aether is mundane and not directly a source of Free Energy.
So we know that something very anomalous and worth of further study IS occurring as no alternative explanation exists, and the odds seem excellent if not conclusive that there is a Free Energy effect in here.
Personally I have no doubt however that if you can correctly use the aether Free Energy is sure to follow and that this device is an important key to aether technology.
BTW, I didn't get anything done on Friday (things came up) and the weekend is never a good time but I have today (Monday) tested my tachometer (costs a grand total of $3.20) and it seems to work well, now I just need  to mount the motor and coil which just means drilling a number of holes.
One thing though is I have begun to doubt that a power controller as I and Larry are using is suitable, they of course output only full power (interspersed with no power) and maybe that is incompatible with the effect.
Another thought is that triac's (used in my circuit and I am sure Larry's too) have a habit of getting stuck 'on'.
If the aether is effecting the triac's causing it to get stuck then it may very well remain on as Larry mentioned.
So Larry you may want to do a test to verify that your motor is really pulling less power, maybe a light bulb in parallel with the motor to see if the Triac is indeed not turning off.
OilBarren
QuoteAnother question for Thane to quench my interest:  have you had any personal evidence/experiences that correlate directly to big oil trying to hinder your work (other than a few spooks on the forum)  I have heard all the conspiracy theories about big oil buying up tech to avoid it coming to market, and since you are so open I thought I would see if you have seen anything personally.  Thanks for the patience and now school is over I am hoping to pick up the physics text and try  to get a better grasp on what is being talked about.
[/size]
YES BIG OIL IS AFTER ME EVERY FEW DAYS OR SO - WHEN I HAVE TO FILL UP MY GAS TANK.
AND WHY WOULD ANYONE COME AFTER ME - NOW THAT OVER 1/2 A MILLION PEOPLE KNOW ABOUT THIS TECHNOLOGY AND ANYONE CAN BUILD IT?
CANADA, USA, JAPAN, NEW ZEALAND, AUSTRALIA, DENMARK AND ENGLAND I THINK ARE DOING IT OR ARE TRYING. THE SOONER THESE PEOPLE GET WORKING PROTOTYPES THE BETTER OFF WE WILL ALL BE.
LEAVE THE TEXT BOOK ALONE - PICK UP SOME TOOLS - BUILD ONE AND REALLY LEARN SOMETHING AND THEN TEACH THE REST OF US WHAT YOU LEARNED.
Thane
