Thane Heins Perepiteia.
0 Members and 67 Guests are viewing this topic.
CRANKYpants
QuoteTidying up your experiment, I increased the gap to 1/4 of an inch, put up four coils, two HV and two HC.  As the variac was back on the Veljko pendulum experiment, ran it at full speed where no changes of speed up or down or any deviation from a steady input rate was noted, with any core connection scheme. I really should cut the core in half as you have done and wind proper coils to
fit the reduced core size. Being a 1/4 inch away, with that mass of core, killed the effect
I_RON,
CAN YOU CLARIFY "NO CHANGES" - DOES THIS MEAN NO DECELERATION FROM THE HC COILS AS WELL?
BECAUSE NO CHANGES AND NO DEVIATION FROM STEADY STATE MEANS NO LENZ EFFECT FROM WHERE I SIT HERE IN OUR NATIONS CAPITAL.
THANKS
Thane
aether22
Quote from: Nali2001 on May 25, 2008, 09:29:54 PM
Hi Thane,
About your last design.
First off I really applaud people with never ending endurance to keep going at what they want to achieve. So you are doing well. Not that many people here in this field go beyond the 'lets talk about it' phase. That is not a critique to them since they have their choice and role as well.
My main interest when I started in this field was "Lets beat lenz law' I have designed simulated and tested quite a few designs and devices and still am. Although it is hard to put in words I have come to the 'believe' that it is not that easy (to say the very least) to redirect the coil's back emf away from the magnetic field that is inducing it in the first place. The one only exists because of the other and in my believe (atm) it does not matter 'where' you let the back emf and rotor magnet's field fight the lenz battle.
I totally agree, there is no way to make 'logical' free energy devices, only by actually engineering the medium of space can it be done. (not to say that aetheric tech isn't logical, it is but it is not known by most and so very few if any 'logical' designs attempt to use it, most fall over the effect or are inspired to build something they don't understand. (and some of the logic based methods that try to find loopholes actually use the aether, but the effect is often tricky to get working)
But when you effect the aether you don't just get one effect normally, look at the GEET carburetor, well over 100 anomalies including the ability to fog film from a distance.
aether22
Quote from: CRANKYpants on May 25, 2008, 07:51:48 PM
ARE YOU SURE?
DEFINITION OF CRAZY(INSANE) - is doing the same thing over and over and expecting different results.
Thane
I'm glad you brought that up.
That is the dumbest definition for anything and I just wanted to tear that cliche a new one!
First it is not the definition of insanity by anyone. (almost any definition of insanity would cover different things entirely)
And second, despite being the definition of Windows ;)  (you really can get different results, thanks Bill) it is also the key to most every success (not just being brilliant but persistent and keep on pushing hard), look at all the coils you made, look at the oft quoted 10,000 filaments Edison proved could not work until he found what would.
I would also add that quantum physics and the aether have real issues with this good for nothing cliche.
CRANKYpants
Quote from: aether22 on May 26, 2008, 12:08:03 AM
IF READ IN THE PEOPLE CONTEXT IT WAS MEANT I.E. ENDLESS EGO DEBATING YOU WOULD NOT SAY THAT - PERSONALLY I PREFER BUCKY'S IDEA...
?You never change things by fighting the existing reality. To change something, build a new model that makes the existing model obsolete.??R. Buckminster Fuller
AND MY PERSONAL CRANKYpants MOTO"
"IF YOU BUILD IT - THEY WILL ALL SHUT UP - EVENTUALLY"
Thane
PS
THANKS LARRY FOR POSTING THE THREAD - NICE TO SEE HOW IT IS REALLY MEANT TO BE - I.E. PEOPLE ACTUALLY DOING STUFF AND SHARING THEIR RESULTS TOGETHER IN PEACE.
A22, CONCERNING THE COIL YOU WANT ME TO SEND YOU (AT MY EXPENSE)
- BUILD YOUR OWN - IT IS THE BEST WAY TO LEARN.
OUman
Quote from: aether22 on May 25, 2008, 11:59:50 PM
For GEET click here: http://www.youtube.com/watch?v=adqtuj_kGC8
