Thane Heins Perepiteia.
0 Members and 50 Guests are viewing this topic.
aether22
Quote from: CRANKYpants on June 02, 2008, 06:34:50 AM
53 OHMS @ 30 GAUGE WIRE - THE OTHER COIL IS 145 OHMS - WORKS BETTER AT HIGHER RPM
HENCE WHY WE USE A HV COIL IN CONJUNCTION WITH A HC COIL - IN A BALANCED MODE OR EVEN WITH ACCELERATION TO GET 20 WATTS w/ ACCELERATED POWER THOUGH A HC COIL - WHERE IT WOULD STOP THE PRIME MOVER DEAD IF EMPLOYED ON ITS OWN.
PLACING THE HC COIL ON THE OPPOSITE SIDE OF THE ROTOR HAS POSITIVE BENEFITS AS WELL.
YOU CAN TAKE LOTS OF POWER FROM A HV COIL IF YOU HAVE MANY OF THEM AND YOU USE THEM ALL TO ACCELERATE YOUR ROTOR - THEN LOAD SOME OF THEM AND USE THE OTHERS TO MAINTAIN THE NEW HIGHER STEADY STATE SPEED.
Thanal Glands.
Yes, and chances are when pulling the same power HV coils will have somewhat reduced overall lenz drag even if they have gone negative.
And yes I am getting it tons at thins kind of time. (resource message)
CRANKYpants
QuoteYes, and chances are when pulling the same power HV coils will have somewhat reduced overall lenz drag even if they have gone negative.
YES - DON'T CONFUSE LACK OF HV ACCELERATION - WITH HC LENZ DECELERATION - IT FOOLED THE "OLD" THANE AT FIRST.
NAIT
aether22
Thanal Glands.
Oh yeah, the fact that the HV coils being shorted instantly effects the pickup coil on the other side before and rpm changes occur if very very much a sign of aether at work, there is no sensible way this can be explained without the sillyness of the aether.
If fact this would make me want to test other things such as to see if a transformer coupling on the rotor or something might be enhanced by the aetheric effect of shorting the Hv coils.
I will have to meditate on this effect further.
aether22
Was in bed but I couldn't stop planning my next experiment which I'll likely try in the morning. (my Bday)
And I've come to a snag, I need to know the details of the increased HC coil output.
Thane:
Was it a voltage increase when they were open circuit?
A current increase under short circuit?
Or a Volt/Amp/Watt increase over a load? (say a light bulb)
My current plan is to wind a coil on the shaft that will be a secondary to a stationary secondary, and the secondary coil short to another coil wound over the nut, and then a pickup coil a cm or so away will measure the increase in power from this electromagnet when the HV coil is shorted.
This simply takes the same effect and moves it's position and which flux source is enhanced.
Since there is no way that the HV coil could be positively influencing the HC coils on the other side based on flux alone this experiment should stand a real chance of working, I hope.
OUman
Quote from: CRANKYpants on June 02, 2008, 06:41:06 AM
DOES ANYONE ELSE GET THIS ERROR MESSAGE AS OFTEN AS I DO?
(like 10 times so far this morning and being online for 15 minutes)
T
Yes, I do. At last we've found something in common!
BTW, I've noticed recently that nested quotes are broken, has anyone else noticed that?
