Thane Heins Perepiteia.
0 Members and 67 Guests are viewing this topic.
LarryC
Quote from: i_ron on June 14, 2008, 01:47:38 PM
The Aspden effect is where when you (is that english?) spin up the flywheel a second time, it's speed
to final RPM is less... because "it" (the aether) remembers the previous rotation. This is presented here as a very convincing proof of the existence of the aether.
Also, the second spin up should be started within several minutes. The effect is reduced over time.
Another "two two" assist.
CRANKYpants
QuoteUFO's and/or masturbation
IS MASTURBATING IN A UFO OK?
T
CRANKYpants
QuoteAlso, the second spin up should be started within several minutes. The effect is reduced over time.
GEEZ GUYS I DUNNO - I COULD HAVE DONE THAT WHEN I WAS YOUNGER...
T
CRANKYpants
SO IN TRUTH THE MOTOR SHOULD NOT BE ABLE TO GO AS FAST BECAUSE IT IS HOT?
BUT IT DOES BECAUSE IT IS SPINNING IN AN AETHER VORTEX?
WHICH RETAINS MAGNETIC MOMENTUM?
THAT DIMINISHES GRADUALLY?
BECAUSE IT'S NOT IN A
VACUUM?
T
LarryC
Quote from: CRANKYpants on June 14, 2008, 02:10:15 PM
VACUUM?
T
Close, the first run should be long enough to make the motor hot, but what is being measured is the time it takes on the first run and second run for the motor to reach a certain rpm. The second run should be shorter if the effect is there. Aether vortex talk, A22 will be in a tizzy!
Like that auto centering option.
L
