Thane Heins Perepiteia.
hoptoad
Quote from: CRANKYpants on June 25, 2008, 07:45:00 PM
NOW FOR SOMETHING SERIOUS.
NEW DEMO VIDEO - HC COIL WOUND ON TOP OF HV COIL.
http://www.youtube.com/watch?v=FmFbINO0dCU
CHEERS
Thane
Nice development - well done, keep up the good work, it seems you're progressing nicely.
Cheers
CRANKYpants
Quote from: aether22 on June 25, 2008, 08:03:35 PM
Didn't you also report HV on top of HC previously or is my memory failing me, what with being dead and all.
YES BUT EVERY TIME PREVIOUSLY THE HC COIL OUTPUT DROPPED (UP TO 50%) WHEN THE HV COIL WAS ENGAGED (IT CAME BACK AFTER ENOUGH ACCELERATION HOWEVER) - SO MY GOAL TODAY WAS THREEFOLD :
1) CREATE HV ACCELERATION - DESPITIE HC COIL LOADING
2) MAINTAIN HC COIL OUTPUT (HC COIL O/P INCREASED AS PREVIOUSLY IT DECREASED)
3) DO IT ALL WITH MINIMAL CORE AREA.
SO I FINALLY (AFTER 5 WEEKS) HAVE SOMETHING I AM REALLY HAPPY WITH ON ALL LEVELS.
T
ALSO...
I HAVE BEEN HAVING SOME CONCERNS LATELY THAT ACCELERATION MIGHT BE DUE TO (OR ASSUMED TO BE DUE TO) A REDUCTION IN CORE FLUX (BECAUSE OF THE HV POWER DROPPING EFFECTS) AND POSSIBLY A REDUCTION IN CORE HYSTERISIS OR AN INCREASE IN CORE RELUCTANCE - SO I WANTED TO ELIMINATE THESE POSSIBILITIES (CORE EFFECTS) FROM THE EVALUATION PROCESS.
THE FACT THAT THE POWER NOW GOES UP INSTEAD OF DOWN IS BETTER THAN I EXPECTED.
CRANKYpants
QuoteNice development - well done, keep up the good work, it seems you're progressing nicely.
Cheers
I MUST SAY THAT MY WILLINGNESS TO PUT MY NECK ON THE CHOPPING BLOCK IS NOT EASY - BUT I KNOW IT IS A KEY COMPONENT OF THE PROGRESS WE ARE ALL SHARING HERE.
AS MUCH AS I RESIST FROM TIME TO TIME (PRETTY MUCH ALWAYS) I DO TRY TO PUT MY EGO AWAY WHEN I ENTER THE LAB AND DO THE RIGHT THING FOR THE TECHNOLOGY.
SO IF THERE IS A POSITIVE DEVELOPMENT HERE - IT IS IN VERY LARGE PART DUE TO ALL THE COMMENTS PROVIDED BY THIS GROUP.
THANKS FOR CARING ENOUGH TO IGNORE MY CRAP.
Thane
aether22
Quote from: CRANKYpants on June 25, 2008, 10:22:52 PM
THANKS FOR CARING ENOUGH TO IGNORE MY CAP.
Thane
You are very generous, don't forget you sure do take plenty of crap.  But yes we do take lots of cap from you ;).
Yesterday I cleaned my garage fully, for real this time.
Today I tested and sadly think I killed Luc's neo magnet discovery. (not related to generators)
So for the rest of today and tomorrow I want to figure out what's next.
I really should just assume the motor is effected due to all the evidence and move on to experiments that use that fact.
However with Thanes results with the HV coils being shorted not dampening the energy induced into the HC coils maybe I can't rule out that the phase is not what is expected, but if that is so then that seemingly means they aren't being induced by the rotor!
Maybe I should do an oscilloscope phase test, will be much easier with a tidy Labrage.
Then again as I am currently getting the effect with high current coils can I even be sure that the effect I am getting is the same as Thanes?
aether22
Interesting to note that the HV coil also raised in voltage when you shorted the HC coil, that is very counterintuitive, and it would seem to backup the thought that the HV coil is somehow not being induced by the rotor flux because the rotor flux must be diminished by the effect of the HC coil.
Hmmm, it would be very interesting for both of us to do phase tests with oscilloscopes and see if we get the same results what with differing results from HC coils.
