Thane Heins Perepiteia.
i_ron
Quote from: CRANKYpants on November 17, 2008, 08:21:37 PM
NEW VID FOR ALL YOU MASTER-DEBATERS...!  ;)
SELF ACCELERATING - SELF EXCITED MOTOR COIL
http://www.youtube.com/watch?v=E8Pprl1Ri18
HC COILS ON THE MORROW.
THANER
Thaner, could you be planer on your explainer?
Are the three coils wound on top of each other on the center leg?
Does the reduced resistance on each segment allow for a stronger effect?
Ron
LarryC
Quote from: CRANKYpants on November 17, 2008, 09:38:50 PM
SO LARRYC AND I WERE GOING TO FLY TO I_RON'S HOUSE TODAY - THEN THIS HAPPENED.
T
Okay, okay, you are the King master-debater. All hail to the king, baby. I've attached a recent picture.
Anyway, the acceleration was truly brutal, looking forward to +HC results.
PS: But, you missed that the Thanerator V2.587972 ray gun had a Tri-toroid design!
Regards, Larry
supermuble
I read the beginning of this thread and skipped to the end. I can't seem to find any information showing replications of the Torroidal transformer that increases power output. I noticed that Thane has made prototypes, but has anyone replicated them? I have some tiny torroids. I would like to build a transformer if it is worth doing so.
Please tell me what I need to construct an over unity transformer, if it can be done with normal materials?
Thanks guys! This has been great reading!
CRANKYpants
Quote from: supermuble on November 18, 2008, 12:53:24 AM
1) START WITH A HUGE TOROID AND WIND TWO SEPARATE COILS ON IT.
2) DRILL A HOLE IN BETWEEN THE TWO COILS AND PLACE AN AC WELDING ROD IN THE HOLE.
3) PUT SOME PRIMARY WINDINGS ON THE WELDING ROD.
4) PUT AC INTO THE WELDING ROD PRIMARY.
5) LOAD THE SECONDARY COILS.
6) MONITOR PRIMARY CURRENT AND POWER FACTOR.
7) IF CURRENT OR PF INCREASES - INCREASE TOROID SIZE.
8) REPEAT.
9) IF PRIMARY CURRENT AND PF DO NOT INCREASE...
10) MAKE A NEW PRIMARY WITH TWO OR THREE RODS.
11) REPEAT.
12) KEEP CHANGING PRIMARY UNTIL YOUR PRIMARY CURRENT AND PF INCREASE UNDER LOAD.
13) REDUCE PRIMARY CORE SIZE A BIT UNTIL PRIMARY DOES NOT CHANGE UNDER LOAD.
14) MAKE SURE SECONDARY SELF REGULATES THE VOLTAGE AC CROSS THE LOAD. (BEMF FROM S1 FEEDS S2 AND VICEY VERSA).
15) KEEP TWEAKING (WIRE GAUGE , # OF TURNS) YOUR PRIMARY UNTIL YOU GET THE BEST Q.
16) KEEP ADDING SECONDARY TUNS TO MAX OUTPUT POWER.
17) TELL EVERYONE WHEN YOU GET OVERUNITY.
18) ACT SURPRIZED WHEN NO ONE BELIEVES YOU.
GOOD LUCK
T
CRANKYpants
YES - ONE AFTER THE OTHER NOT SIMULTHANEOUSLY.
QuoteDoes the reduced resistance on each segment allow for a stronger effect?
Ron
NO - THAT'S ALL THE WIRE I HAD AT THE TIME - THE SECOND AND THIRD WINDINGS WOULD PROBABLY WORK BETTER WITH ADDITIONAL TURNS.
THAT WAS A DEMO COIL FOR THE OTTAWA UNIVERSITY ENGINEERING STUDENTS WHO ASKED ABOUT HOW TO INCREASE RPM AFTER THE A COIL MAXXED OUT.
BTW: A SINGLE COIL W/ 160 OHMS DOES NOT ACCELERATE - BUT TWO SEPARATE 80 OHM COILS DOES BEAUTIFULLY ALSO WINDING THREE 80 OHM COILS SIMULTANEOUSLY DOES NOT WORK EITHER.
THANER THE EXPLAINER
CAN I MAKE THIS PLAINER?
T
