Thane Heins Perepiteia.
0 Members and 127 Guests are viewing this topic.
woopy
Hello Thane
I am a newbie from europe and i would like to congratulate you for the great work and the amazing progress you have done since the beginning of this topic.
If i understand right, i can replace the electric prime mover with anything else, for example à water turbine or windturbine etc...
And if i have also seen right,  by engaging  the 3 concentric HV coils , the HC coil generator can go from 0.27 watt to 8.2 watts  without adding any energy.
And if I assume for fun, that the 0.27 watt of theHC coil at 900 rpm could represent the energy needed to power a house (very very small house ::)),  by simply engaging the 3 concentric HV coils, the HC coil by accelerating, could provide up to 8.2 watts or could power more than 30 of these very very small houses
So if i have a windturbine in my garden to power my house, and this turbine is coupled to  a Thane's generator, (and assuming the same wind speed ), i can dramatically reduce the diameter of my propeller to get the same amount of energy as without your system.
Or better, i can keep the same propeller diameter to  turn a much bigger Thane's generator and  power not only my house but all the village.
Whoooow !! that is absolutely fantastic ! I can simply say BRAVO, and hope that i can buy or replicate a Thane's generator as soon as possible. Keep up the good job, this is very promising and thank you for sharing.
I will go on following this thread with a lot of interest
Laurent
CRANKYpants
QuoteIf i understand right, i can replace the electric prime mover with anything else, for example à water turbine or windturbine etc...
THAT IS RIGHT - BUT YOU NEED TO BE ABOVE THE CRITICAL MINIMUM SPEED FOR THE HV COILS TO WORK.
QuoteAnd if i have also seen right,  by engaging  the 3 concentric HV coils , the HC coil generator can go from 0.27 watt to 8.2 watts  without adding any energy.
THIS IS A DEMONSTRATION PROTOTYPE FOR THE STUDENTS AT OTTAWA UNIVERSITY - YOU ONLY NEED 1 HC COIL BUT YOU CAN ALSO HAVE 3 OR MORE IF YOU PREFER.
QuoteAnd if I assume for fun, that the 0.27 watt of theHC coil at 900 rpm could represent the energy needed to power a house (very very small house ::)),  by simply engaging the 3 concentric HV coils, the HC coil by accelerating, could provide up to 8.2 watts or could power more than 30 of these very very small houses
OR MAKE 10 CONSENTRIC BI-COILS AND PRODUCE 1000 WATTS AT 3000 RPM.
QuoteSo if i have a windturbine in my garden to power my house, and this turbine is coupled to  a Thane's generator, (and assuming the same wind speed ), i can dramatically reduce the diameter of my propeller to get the same amount of energy as without your system. Or better, i can keep the same propeller diameter to  turn a much bigger Thane's generator and  power not only my house but all the village.
FIRST YOUR VILLAGE THEN EUROPE.
QuoteWhoooow !! that is absolutely fantastic ! I can simply say BRAVO, and hope that i can buy or replicate a Thane's generator as soon as possible. Keep up the good job, this is very promising and thank you for sharing.
Laurent
HOPEFULLY YOU SHOULD BE ABLE TO PURCHASE WIND GENERATORS BY NEXT SUMMER IF ALL GOES WELL.
CHEERS
Thane
Charlie_V
QuoteInput power of last test?
IRRELEVANT
Why?
efoda
Quote from: CRANKYpants on November 23, 2008, 06:48:32 PM
IRRELEVANT
Irrelevant? Ok. If your motor is drawing 10-15 watts to output .27, and then requires no ADDITIONAL power to output 8.2 watts while still requiring 10-15 watts to run, then maybe it's just me, but this doesn't seem all that amazing. If you can explain more why it's irrelevant, I'd like to hear it.
NO - BUT THE MOTOR INPUT WOULD BE ZERO IF THE HV COIL ACCELERATED THE MOTOR ABOVE THE RATED SPEED OF 3500 RPM.
Yes, I understand what the results might imply. Do you have any plans in performing this test? If you did and the results showed a runaway motor acceleration condition whereby output exceeded input, then I'd most definitely agree with you that input power is irrelevant.
woopy
thanks Thane for replying so fast
and another time whoow and bravo for the possibilities i can see
Now, If i consider the posts of Charlie V and Efoda (and lot of people on this thread) and the question about input versus output, I have to understand this :
If i have in my garden a windturbine of a given propeller diameter (let's say 5 meters diameter) coupled to a
good  "normal s" generator
And  i assume that, at  a steady  windspeed  of 30 kmh this "normal" generator can easily power my house.
Now, i replace this  "normal" generator by a brand new Thane's generator (of course capable to spin the rotor at the right speed to animate the HV coils properly).
Can I expect that with the same propeller (5 meters diameter) and same wind speed ( steady 30 kmh) , this new Thane's generator can power not only my house but also all my village (about 30 more houses) ? and perhaps more ??
If i look right to your videos it seems to be possible, and pardon me to be estonished , i am not only estonished, i am  completely upsidedown...and very happy to see that this world can reserve very good surprise to a  sleeping human beeing
hope the best and i am looking forward to see more and more
thanks
Laurent
