Thane Heins Perepiteia.
CRANKYpants
Quote from: aTg on February 22, 2009, 05:52:30 AM
http://www.youtube.com/watch?v=clCeqwevLXc
NICE WORK AAAALEXISSS!
AT SOME POINT IT WOULD BE NICE TO SEE BEFORE and AFTER DATA...
SUCH AS:
MOTOR INPUT CURRENT before LIGHT BULB LOADING = ?
MOTOR INPUT CURRENT after LIGHT BULB LOADING = ?
THIS WILL GIVE THE VIEWER AN IDEA OF HOW THE MOTOR IS REPONDING TO LOAD.
ALSO IF YOUR MOTOR IS TOO POWERFUL IT MAY NOT BE AFFECTED BY A SMALL LOAD?
CHEERS
Thane
aTg
Hello, Thanks for your interest in my video. will soon upload a video better documented.
My configuration is;
Small induction motor-2900RPM max 150W
30x5mm-diameter magnets
coil-0.6mm diameter (correcterd)
First test, the engine powered 60vAC connecting the load directly or 12v bulb and 5w to
resistance decelerates the engine to stop.
Second and video evidence, then add a rectifier and an electrolytic capacitor 100v 4700nF low engine
But revolutions are not stopped, the capacitor holds a charge and increases gradually increasing also the brightness of the bulb.
In my experiment, the rotor accelerates slowly but does not reach the same speed with no load on the coil, or at least to my knowledge.
The trial has lasted very little and got loaded up in the condenser 3v also lit the lamp.
I have something to improve security before the imam comes out flying somewhere near my face:)
CRANKYpants
Quote from: aTg on February 22, 2009, 08:49:30 AM
KEEP UP THE GOOD WORK!  8)
T
sushimoto
Hi,
thanks for sharing this.
I do like your setup which separates the "kinetic mass"
from the electro-magnetical part of the system.
Thanes dentist would hate this kind of experimentation.. *grin*
2cent,
sushi
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
i_ron
coil-4mm diameter
Very nice test setup aTg,  You should be able, with just a single coil, to show the Thane effect
if you can wind a coil with many turns of much finer wire....
Take Care,
Ron
