Thane Heins Perepiteia.
CRANKYpants
I'LL LEAVE THE LAST WORD TO OUR FORMER PRIME MINISTER...
T
i_ron
Quote from: CRANKYpants on March 17, 2009, 08:04:33 PM
T
Then there's this fascinating quote from the former Prime Minister and ontological theorist,
    "Mr. Speaker, I talked with President Clinton and earlier today I talked with the Prime Minister of Great Britain. The goal that we all have is to make sure that Saddam Hussein respects the resolutions of the UN and stops the production of armaments like biological weapons and so on that are extremely dangerous. We have proof that they were producing and are still producing them and we want to terminate this production. It is extremely dangerous for countries around the world if we do not stop Saddam Hussein with this production." .... "As everybody knows, there are a lot of people who are trying to persuade Saddam Hussein to change his position. In order to have him change his position we have to show with determination that if he does not change his position we will be there to make sure that he stops the production of this absolutely unacceptable armament he is building at this time." (Source: Hansard,�February 9, 1998)
Ron
hoptoad
Quote from: i_ron on March 17, 2009, 09:34:27 PM
Ron
So unfortunate for all the innocent people who've needlessly suffered because of that particular "proof".
Cheers
CRANKYpants
"This means 100 times less drag torque felt by the drive motor! (therefore the common shaft speeds up when coils are shorted, duhhhh)
Now I will also say, that heavily loading certain geometry of generator, can produce some gain.  I have several examples on the bench which do.  But they are proprietary and I don't care to share this with lists.
You have to measure True power at the shaft input via torque sensing and speed, against True output power.
There could be a small amount of gain in his sloppy and amateurish system
Pick or know the optimal final speed of the system.  Use only this shaft speed for all measurements.
Measure all parameters in a generator "no load" condition including:
Then include the mag fields and measure the input drag power (torque times angular velocity).
overunity may not come in the form you wish it to!"
DMBoss
"As has been stated by others, but in another way:
1. you take a motor(x) that runs at 'x' watts
2. put the coils(y) next to it, motor runs at 'x+y' watts
3. activate(z) the coils, motor runs at 'x+y-z' watts and produces 'w' watts.  Net = (x+y-z) + w
To be OU #3  needs to outperform #1
Thanks!"
Ron
???   "You have to measure True power at the shaft input via torque sensing and speed, against True output power".   ???
DMBoss
"Ryobi, running with no load on line voltage, is not that efficient.
On 117 volts it uses .92 amps, wow, 107 watts!"
Ron
"Oh, btw, yes you are correct, it should be 96 watts (or so) I put that in like that to see if anyone
was paying attention.... do you believe that? lol"
Ron
CRANKYpants
"What the squabble is about. This was basically a private matter"….
Ron
"PS:
Any information received will be treated as confidential and held as if an NDA had been signed. RHP"
Ron
"it would seem I have been shown the door"
Ron
