Thane Heins Perepiteia.
baroutologos
Hello,
I am possitively surprised to see your thread still active over here. I see you have made progress, but the real issue of demonstrating OU still you miss it.
If you want my piece of advice is you have nothing to gain by demonstrating it. let others do it for you. Let the people speak. I sorry to upset you that you could not patent this type of technology and expect be rich and famous :(
The greatest inventor of humanity i.e. Nicola Testla miserably failed to propagate the free energy technology. Why you think will succeed?
Besides the poetic words, I think it is time to mass replicate your device. I have been given much though and i realized that even though the HV coils could generate some 10-30 watts of power, this is nothing compared to the 100-200 watts consumed by the grinder motor.
So the bottom line is IF any of Perepiteia anthousiasts want to harvest any considerable and usefull effects you must replace the induction motor with a pulsed permanent magnet motor or still better for greater efficiency with a Adams motor or even better Bedini SG motor type. (this advice goes for the inventor also).
For now i am gathering resources...
By the way... Happy Easter
Regards,
Baroutologos
hydrocontrol
Quote from: baroutologos on April 13, 2009, 03:48:56 AM
I believe what Thane is trying to do is optimize and maximize the power output. This can only be done with data collection and research of different coil/core combination. At some point you have to just "go for it" but if Thane had attempted to be content with using the Microwave transformers he would have not reached a higher potential like he has with the newer core materials and the newer coils. That form of research takes a lot time.
Actually I believe there is no need to change out the motor or even have a motor. The rotor magnets with his current cores/coils combination should be usable to get the rotor spinning. All Thane would have to do is add some rotor position sensors then pulse all the HV coils externally at the proper time to get the rotor spinning. Once at the needed RPM just disengage 3/4 of the coils and use only one to keep the rotor spinning. The other cores/coils can harvest the power. Part of that power can feed the remaining coil that keeps the rotor spinning.
baroutologos
Quote from: hydrocontrol on April 13, 2009, 09:22:52 AM
Hi Hydro,
I guess you are right about that. But in case we are dealing with inefficient systems or frictions are too much or..... don't  know what, an efficient motor will always be beneficial.
anyway, experimenting will tell
hydrocontrol
Quote from: baroutologos on April 13, 2009, 09:41:22 AM
Hi Hydro,
I agree that an "efficient motor will always be beneficial". I would also say that a Ryobi motor on a variac is not an efficient motor. If Thane could actually get the output of the coils to feed the Ryobi without a battery in between that would pretty much assure that major improvements could be made.
CRANKYpants
Quote from: hydrocontrol on April 13, 2009, 10:32:18 AM
UNTIMATELY WE WON'T NEED A MOTOR AND ARE WORKING TO ELIMINATE IT ALL TOGETHER AND USE THE GENERATOR COILS AS THE "MOTOR" TO BRING THE SYSTEM UP TO SPEED AND THEN SWITCH OVER TO GENERATOR MODE AND THAT'S IT.  ;)
AT THAT POINT OUR INPUT WILL BE ZERO!!!  8)
UNFORTUNATELY THIS STUFF TAKES MORE TIME THAN SPECULATION AND ARMCHAIR INVENTING...
ENCLOSED OUR NEW STATOR CORE.
T
