Thane Heins Perepiteia.
CRANKYpants
QuoteThanks for being so upfront and informative with your research.
IT IS ENTIRELY A SELF PRESERVATION MOVE!  ;)
THE MIPB'S WILL HAVE TO TRACK DOWN ALL THE MEMBERS ON THIS FORUM ALONG WITH ALL THE YOUTUBE VIEWERS AND QUIETLY OFF THEM BEFORE THEY COME FOR ME.SO AS NOT TO RAISE THE ALARM.  8)
THEY KNOW WHERE YOU LIVE!
T
SkyWatcher123
Hi folks, Thanks for the updates Thane, good ideas there and your welcome for us being your disposable bait for the dark clowns. you make me laugh.  ::)
baroutologos
Hello,
Just in the effort to replicate your work, some key points are needed to be mention.
Ok, i have read much of this thread but when it comes to the set up of your own, matters arise that you never give much thought.
So, the point is to spin magnets fast in front of a high impendance coil fast enough till Lenz law ceases to exist. In fact those coils above some critical rpm, assist rotation. Ok plain and simple. Instrcuctions now: :)
1) Magnet arrangement. Ok any magnet arrangement with suficient rpm will do the trick i suppose. But the most efficient in order to initiate the process for a given coil is NSNS configurations?
2) Number of magnets.
I suppose for a given rpm of rotor the more magnets (in a reasonable mode) the better the effect.
BUT, does this effect correlate with magnet SPEED over the coil OR just the FREQUENCY of them? Higher frequency means higher speed of course but, what i am saying is if for a given set up the process of accelaration starts at 1500 rpm (say) with 16 magnets will be the same rpm with 6 magnets? (no output measuremnets just process start)
that's for now. perhaps later may have some more...
Regards,
Baroutologos
CRANKYpants
Quote from: baroutologos on April 15, 2009, 03:46:10 AM
I suppose for a given rpm of rotor the more magnets (in a reasonable mode) the better the effect. BUT, does this effect correlate with magnet SPEED over the coil OR just the FREQUENCY of them? Higher frequency means higher speed of course but, what i am saying is if for a given set up the process of accelaration starts at 1500 rpm (say) with 16 magnets will be the same rpm with 6 magnets? (no output measuremnets just process start)
Regards,
Baroutologos
FREQUENCY.
T
Pageygeeza
I made up another coil ring today, using thinner core wire, less passes over the face, but more runs and got a 15% increase in power output.  Now I could easily add more wire, 18 more magnets and way more rpm to the equation.  For an AC output on my second try I think is pretty good.  The good thing about it, is I can use it as a motor too. :D
