Thane Heins Perepiteia.
0 Members and 31 Guests are viewing this topic.
hydrocontrol
Quote from: adlep on May 04, 2009, 03:49:54 PM
Lets hope that Mr. Thane and his invention are fine.
They guy is a bit eccentric and difficult to deal with, but I have seen nothing but good intentions coming out of him. I wish him nothing less than all the best.
Hopefully everything worked out and Thane is currently preparing a nice update for all of us...
I suppose there are two possibilities.
1) It worked and Thane is working on editing and uploading a new video.
2) It did not work and Thane is working on understanding and solving the reason why it did not work.
I think we all are hoping it is #1 but even if it is #2 all is not lost. I am sure it will work eventually. Thane did do a self imposed demo date and there was a lot of work left to do just from his last update to get the system fully populated. It could be there was just too much to do in the time frame available to get to the self running point. If he gives us a self running demo sometime in May I would be happy. We all have waited this long. A bit more time is not going to hurt anyone...
Fred Flintstone
Thane - if you're running short on time, just give us a quick overview of the demo. Many of us are very anxious for an update....
Fred
baroutologos
Hello @ All,
I am waiting as most of you Thane's demo results. Anyway, you should not expect much to happen since even succesful though might be, things seldom change like that.
I was pondering the other days with Perepiteia and compared it to Adams motor. After all, they are magnets & coils right? :p
So venturing in this site http://www.free-energy-info.co.uk, under chapter 2, Adam motor section i stumbled across this (see attached image)
Then i had a laughter :D.
I merely compare it with the HV coils of Thane's setup that all have a common magnetic "ground" in toroid, boosting there power by 37% each.
So, this has been observed and done before. by no means i try to dwarf Thane's creativity and invention. But what i am trying to say is that this kind of technology is surpressed or to put it mildy ignored enough to be forgotten, so every time we RE-INVENT the wheel.
Have a look.
regards,
Baroutologos
ps: Thane we wait your news!
hydrocontrol
Quote from: baroutologos on May 05, 2009, 05:21:55 AM
regards,
Baroutologos
There are differences but there is a lot in common. I think the key that Thanes found was using fine wire to cancel / delay the Lenz effect. Every Adams motor I have seen used heavier gauge wire so there was always a limit that would allow the Lenz to kick in. The key is that for Lenz to work it has to have current to flow and not voltage to flow.  So if you have voltage flowing without the current then Lenz does not kick in (as bad). The conversion from voltage to current occurs elsewhere so the rotor is not effected.
baroutologos
Hi Hydro,
Yes you are right about that. There are serious differences. :) i am not an anihhilist. i agree. But... see it from another perspective.
Imagine you want to replicate Peripeteia, ok? you gonna use thick gauge wires for the motor power coil (that's the grinder) and finer gauge wire for the accelaration part. (HV coils) You should agree by now.
Image you want to eliminate the two different kind of coils so you want a SIGNLE COIL that combines HV acceleration and power creation in a delicate balance.
I think that's the original Adam's motor.
I hope i did not confuse you. Anyway, Thanes smart setup distinguises the accelaration part from the motor part. This achieved to better and more efficiently (i think) make the two different systems.
Of course, that is my oppinion. :D
Regards,
Baroutologos
