Thane Heins Perepiteia.
Heinstein
Dear All,
Don?t forget that this transformer IS INTENDED to be a high voltage low current unit.  P = V^2/R with low losses due to heat. So we will definitely try the higher frequency approach ? Luc?s said he?s buying the champagne if we succeed.
Thane
Bruce_TPU
Hello all,
I have been following, silently watching.
Hmmm....Starting to sound like a Toroidal Power Unit.
@aether22
Brilliant analysis.  I believe this is also a part of the mystery that is Steven Mark, and his discovery.
@ Thane
Welcome to the Forum, and thank you for your commitment.
A quick question:
Have you ever attempted the same idea as your bi-transformer, but instead of two secondaries, having four?  One at each quadrant of the toroid?  What would the result of that be?
When you pulse your primary, according to aether22's suggestion, I would suggest an attempt at 35.705 Khz or 245 Khz.  A long story why...but please keep it in mind.  I would also suggest using extremely fast pulses.   Extremely fast.  ;)
Happy experimenting and I look forward to hopeful results.
Bruce
gotoluc
Quote from: Heinstein on February 17, 2008, 08:06:03 PM
Dear All,
Thane
Hi all,
first I would like to thank Thane for joining the forum. It's going to really help to speed things up ;)
I would like to ask all of you for your help with ideals and explanation to make a new Primary for testing Toroid 3 once again but this time with higher frequencies than 60Hz. I will be the one making a new one and need all your help and expertize.
As you have seen in the pictures, the primary that was quickly made for testing could possibly be improved. The core of the primary is  2 pcs. of 1/8" (3mm)  Thick x  4 1/4" (108mm) Length x 1" (25mm) Wide solid steel strips of angle steel you buy in a hadware store. The magnet wire looks to be 16 gauge.
Thane gave me some thin steel transformer laminations which I could cut and group together of core. What do you think?
How many turns of wire, how Thick a core and how Wide?  The Length has to stay as above to fit inside the Toroid.
Please you input a.s.a.p.
Luc
Mr.Entropy
Can someone (whoever has it) post the DC resistance and turn count of Thane's primary?
Thanks,
Mr. Entropy
Hi Luc,
try maybe also with a AM ferrite rod and
wind there maybe 2x100 windings on there both winding in paralel
( Bifilar) and use the Tesla style connection, so the flux in this primary
does not cancel out, but add, but has much more capacitance.
Also then try to use much higher frequencies like in the Khz range and
try pulse the primary coil with a MOSFET circuit.
OR you can try your other circuit,
http://www.overunity.com/index.php/topic,4124.0.html
where you had the sparks at the magnets
from this afternoon and do this pulsing with the primary and
then use both secondaries in parallel or series to feed the bridge
rectifier and charge cap.
Should also work quite well with these spark pulses..
Good luck !
Regards, Stefan.
