pulse motor and transistor problems
Started by jasonspinmaster, February 08, 2008, 03:52:00 AM
jasonspinmaster
gezgin
Do you want to make optical trigerred timer circuit or "schmit trigger"
for pulse motor control?
this motor is bedini or newman's motor or normal motor?
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
jasonspinmaster
i am looking for a circuit to fire a 2N3055 transistor,as to fire the coil, when the light of the sensor is blocked. i think the wave coming out from the sensor is a square wave so i do not need a schmit trigger
i read the web page you sent me and i have copied the large cicuit.
i am getting a very small pulse. (which is a great sign) if a change the resistors and the cap will that put more current in to base opening up the transistor
pese
Quote from: jasonspinmaster on February 08, 2008, 09:28:04 AM
what do you mean by  taken a dvm
dvm
digitalvoltmeter
analogvoltmeter
voltmeter
to read 0,7 volts or wahat you want
jasonspinmaster
i am getting 0.12 volts low state out off  555 timer with the resistor
