Thanks to ALL for your help!!
Peter Davey Heater
Started by storre, February 09, 2008, 11:00:32 AM
0 Members and 27 Guests are viewing this topic.
storre
Quote from: ramset on May 16, 2008, 03:21:37 PM
NEWAGE your actual pic shows three half spheres      also the illustration #1[inside bell] seems to flatten out past the midway point   Chet
3 spheres? I only see 2.
Also doesn't matter if it's flatting out. It's just a bell. You could do the same thing with a cylinder and it's already been done in many H2O engines. If it rings, then it will do the trick. I think we are making this much too complicated. Making a bell that rings at 1600Hz is toooo simple! Grinding is tooooo easy! This device doesn't require any electronics! Doesn't require any math! Doesn't require much skill. Anybody that can tune a guitar by ear can make this device with a little trial and error! I love how these things were done in an age where complicated math and theory could not get in your way. Keely was a musician, Peter was a musician. Anyone that has turned up the sound in a house with things that rattle has to wonder why some things rattle and other things don't depending on the music! Take 2 tuning forks at the same frequency and see the magic of resonance by striking only one of them and watch while the other magically starts vibrating as well. Take 100 of them and strike one and watch the other 99 ring as well. Do the same with the first and last string of a guitar. This stuff has been in our face for centuries but only a few seem to see the power of resonance and understand how simple it is. Push a kid on a swing and we naturally know WHEN to push and when to not. We use electricity like a brute and pound away using unnecessary amperage. It's like pushing your kid on a swing but pushing like mad even when the swing is no where near the pusher! As above, so below! As in the macro as in the micro! :)
b0rg13
Quote from: ramset on May 16, 2008, 03:30:32 PM
SO... the mains in NZ is 110 volts 50 htz  Davey used 2.5 amps  is this all correct?  Chet
the mains in nz are around 230 to 240v
if you want to get out of the rat race,you have to let go of the cheese.
ramset
Thanks Borg @ storre  why do you think this way [Tubes][pipes] [easy]  seems if this was the case it would be done [has it ]   Chet ps besides Davey
Thanks Grandma
devrimogun
Quote from: storre on May 16, 2008, 07:54:34 PM
Last message before I leave. My point exactly! Lets not make these 2 bells complicated.
Look at @Nerzh's experiment (I gave the link above) he did not do any of the tunings and still
got a COP of 1.
Storre I think you are the closest to this. But start with suitable bells.
Good luck.
I just received an email from a company in Taiwan www.accesspro.com.tw
they sent me pictures of a product line they made (it is a spam)
the explanation they make is "special syntony sound box
This can be put on any surface and make the sound transmit by it."
There is a cylinder shaped one and a bell shaped one.
I am sure you will find it in their WEB site.
May be of use.
All the best.
storre
Quote from: ramset on May 16, 2008, 08:23:34 PM
I believe it has been done over 100 years ago by people that saw music and electronics intimately related. If you've seen the Peter Davey videos you can see he's done it also. Water does not boil that fast even with 220v. I've tried it and a cup of water using a coiled up wire across to 110v mains takes at least 30 seconds to boil. It's actually pulling 2000W to do that. We have to see electronics and music as the same field of study. They are the same in terms of resonance. I will use the guitar again as an example. Tune the first and last string so that they are EXACTLY in tune with each other. If you strike the lower E string strongly without touching the higher E string and then stop the lower E string from vibrating you will hear the higher E string vibrating even though it was never touched. If you then detune (even a little bit) one of the 2 E strings so they are not in resonance with each other, then the effect stops.
This outer (or inner?) bell has to be tuned exactly to a harmonic of the oscillation of the AC mains. Then the bell will serve as an amplifier to the oscillation of the mains frequency.
The same theory holds true with the example of a soprano singer breaking a china glass by hitting the exact frequency of the glass. Put water on your finger and slide around and around the rim until it rings and then play that frequency on a sound system at a high volume and you can shatter the glass. I also read stories about how Keeley could break a quartz rock into powder with a resonator and how Tesla could vibrate a building to destruct itself using a resonator. They both understood the same thing and then some?
I think someone here will make a working model very soon :)
