My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
helmut
Quote from: PYRAman on February 19, 2008, 04:39:11 AM
The pyramid produces so much heat that one can not hold its hand on the middle of the copper pipe. so it is overunity of course, one could not heat a pipe with only 20 watt that one puts in the loudspeakers.
@PYRAman
Tanks for the answer.
I like to replikate the type of Pyramide.But i need a usefull instruction and some more Help of you.
May be,that there are others with me.
Will you help ,to work out some sketches and list fo the required parts.
And would you bring some more Pictures from the Pyramide,that you all ready hafe made.?
Many Details are better explained by Pics  than with Words.
I think,it is yust fair to all the others,who like to spend time and money just for a Hope.
helmut
MeggerMan
Hi Pyraman,
Thank you for your reply.
The idea of two metals formed into a ring sounds like a thermo-couple, but can you produce a lot of power from it?
I am not sure where I can get the musical sand/quartz sand from, do you know where I can get it from.
All the other parts are not a problem.
Here is a link the diagram of the great pyramid at Giza.
http://en.wikipedia.org/wiki/Image:Great_Pyramid_Diagram.svg
In your photo, are you saying the sloping grey tube is the grand gallery?
The angle looks very different to your construction.
A 20 watt soldering iron element could heat the a small section of pipe to a temperature too hot to hold over the period of about an hour.
If it is able to heat the pipe too hot to handle within say a few minutes then I would say that it is quite possibly OU.
Can you ask your friend what other examples of generating heat or energy exist.
What about the Tokomak, this is big science and is supposed to generate vast amounts of heat from deuterium or tritium as fuel.
http://en.wikipedia.org/wiki/Tokamak
Rob
sparks
    Hmmm,
     All matter has energy potential.  It is inertia.  To get change or energy you need only to upset the inertia of the matter.
A spinning top  needs only to have it's axis changed to convert inertia into energy.  If the atomic structure of the sound sand is considered inertia on an atomic or molecular scale then by adding sound energy into this structure you upset the inertia or resonance of the system and energy will insue.  This process must be in harmony with nature.  Whereby nature restablishes the inertia of the matter and there is a harmonious flow of energy through the matter.  The Earth converts sunlight into infra-red wavelengths of energy.  Man has upset this flow of energy by releasing energy from inertia of the carbon cycle.  There now exists an ever increasing field of infra-red standing wave energy.  The sunlight constantly charging this field.    The idea expressed about a blackbody collector coupled to an electrical circuit is very interesting.  Infra-red wavelength emmission acting as the primary on a transformer. hmmmmm.   I am working on an idea about creating reflective emwaves that would hetrodyne with the standing wave infrared field over a large area.  Each time the wave is reflected it would gain energy from the standing wave field.  An infra-red transformer at the end of the antennae lattice would work in nicely. ;D
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
magpower
Quote from: PYRAman on February 19, 2008, 04:58:10 AM
Sorry for my late answer but only yesterday I came again in connection with the so called half-god. Now I know, he is a male, he told me that. He sleeps many days in a row, then he is again many days awake, that is his way of life because he is extremely old.
However, he seems to know what is in my mind without asking him, so he begun telling me about magnets. they are like batteries whose energy is very hard to extract, once loaded, that is why the magnets hold their field for tens of years, and this fact lead many people to the FALSE IDEA that a motor made with permanent magnets would run for many years withoud adding energy in the system. But if one tricks the energy out of the magnets, making a magnet motor with them, they will demagnetise quite quickly, maybe in a few days, so this is not a real overunity system. It is like when you feed a motor from a normal battery that has current for a few days. So he said, we should stop trying that.
We must make ENERGY COLLECTORS like the Great Pyramid or any other kind of collector, because we can not create energy, only the nature does this. We can only collect energy.
He gave me another idea of a device that changes heat into electricity, very simple if it works.
So, it is a rod of a low resistance metall, maybe copper, whose ends are brought together and connected through a metal with high electrical resistance. If we heat a half of the rod in some way (concentrating Sun's heat maybe?) the rod produces a lot of electrons which then go around through the other metal and through the rod again like in a one winding coil. A very strong pulsed magnetic field is created and we can transform this pulsed field into electricity.
I think I will try this too, in the sommer.
Quote from: MeggerMan on February 17, 2008, 05:00:24 AM
@Pyraman,
All the pieces in your story seem to fit.
I guess you need to measure the heat generated by the pipe does exceed the input from the speakers.
I have seen heat and cold generated from sound waves so this is not unusual, but if it can be proved to be OU then fantastic.
Can you ask your friend about the whipmag magnet motor and the TPU (Steven Marks toroidal power unit).
If we cannot get an OU device working then we just wait till next year when our creators turn up and put us right. Maybe I can get to go back and see the home planet (Niburu?).
[edit] Found an article about solitary sound waves for heat and energy transfer:
http://focus.aps.org/story/v4/st24
Another link showing heat turned into electricity via an acoustic wave:
http://www.americanscientist.org/template/AssetDetail/assetid/56188
[/edit]
Rob
Pyraman
Thanks for getting back, but look at this http://www.ctglabs.com/electricity_from_pyramids.htm  is something that Thomas was doing but more advanced version. Can you get electricity from pyramids that the big question. Maybe the Half Gods could tell us more about this. Like to see more pictures and try this out. I guess a steel frame is not good.
Thks
Wayne
mxt
Quote from: PYRAman on February 15, 2008, 08:07:31 AM
And now some other good thing:  there is one suggestion that this "half-god" gave me for having a much better health and recovering from the schock waves that went through my body during the mental communication. I had to build another type of pyramid which does not contain the energy inside, like the Great Pyramid does, but spreads the energy around. This pyramid must be built only with non-metallic parts (glues including) its height must be at least twice the length of the base line (three foot) and it must be oriented to the geographic N-S line (not magnetic). I was told to chose a place inside the house and put the pyramid there and NOT MOVE IT anymore for a very long time. He said that the pyramid will build a strong field, bathing the whole house in it and preventing all inhabitants from becoming ill. I must say that I feel a lot fresher and stronger since this sharp pyramid is in place.
I suggest that all of us build such pyramids and place them inside our houses in the middle of a chamber, away from the walls.
I am sure, when every house will have such a sharp pyramid in it, most diseases will be history. If you have the skills to build the sharp pyramid, please show to all your friends how to do it. We must be all together!
But one should pay attention to the orientation, the geographic north will not be shown by a compass, but by the Polar Star, so it might be a little tricky to find the right direction inside of a house.
Good luck !
PYRAman
Can you give us some details on how to build this sharp pyramid?
I have seen the meditation pyramids (energy inside) which are only the frame.
Do we need to build:
1. Only the frame
2. The frame covered with the non-metallic material
3. The frame covered with the non-metallic material and filled with non-metallic material
Which of the sharp pyramid constructions makes the strongest energy field around it?
What material is best for this type of the pyramid?
Thanks for the information PYRAman and "half-god"!
Mx
