My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
sparks
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
rensseak
Quote from: mxt on February 22, 2008, 01:08:56 PM
Quote from: PYRAman on February 22, 2008, 11:10:42 AM
Maybe this is the way how the quarz sand is pumped with sound in the Great Pyramid. I used loudspeakers  ;D
Quote from: sparks on February 21, 2008, 07:23:15 PM
    Could a pyramid act like a stethescope for the Earth?  Concentrating sound waves at the apex or causing them to resonate in chambers within the structure.  Maybe they even receive low frequency electrical waves and reflect them into standing wave fields within the structure.
Here is what I found in the same book I posted above (THE COMPLETE PYRAMID SOURCEBOOK) Page 147:
"Dr. K. explains his discovery of this field (energy field) by first stating that the Great Pyramid was built to intentionally amplify basic energy fields of the Earth on a subatomic, quantum level. He calls these fields? inerton fields or waves and has measured them in model pyramids. He proposes that the Great Pyramid is a resonator of these fields produced by the earth. It would be a new physical field like the electromagnetic or gravitational field. This field is what affects the materials placed in the pyramids and caused the sharpening of the razor blades.
This inerton field is generated due to friction of moving elementary particles through space. Dr. K does not believe that space is emptiness like Einstein claims but is filled with a substrate, some kind of an ether, as scientists in the 19th century and early 20th had believed. There is more data recently to support the presence of this space substance. It is hypothesized that atoms of the earth vibrate and interact with the ether generating inerton waves. The Great Pyramid concentrates these waves and is saturated with them. These waves then cause the changes in the materials. Did the builders of the Great Pyramid know of these waves and built it as a resonator of them? He would like to measure this field in the Great Pyramid to prove his theory. Inerton waves spread in the resonator along two mainstream directions, which correspond to the East-West line and the vertical line."
Mx
Not only, also this is pritty much interesting:
Arab?s was to place their women in tombs with gabled ceilings (as
opposed to flat ones for men), so this room came to be labeled by the
Arab?s as the Queen?s Chamber. The chamber dimensions are 18 feet
10 inches by 17 feet 2 inches. It has a double pitched ceiling 20 1/2
feet at its highest point, formed by huge blocks of limestone at a slope
of about 30 degrees. When this chamber was first entered, the walls
were encrusted with salt up to 1/2 inch thick. This has been removed
since then, most likely when the chamber was cleaned. Salt
encrustation was also found on the walls of the subterranean chamber.
The cause is unknown.
amigo
If the chambers were filled with salt water, than whatever process happened might have left residue of salt on the walls once the water evaporated/leaked out. Do they mention what kind of salt it was (magnesium chloride,  natrium [aka sodium] chloride)?
Salt water could've acted as a collector, a converter or a conductor of waves or energy (which are basically one and the same, oscillation is energy)...
sparks
Salt water was used in the very first capacitors the leyden jar.  It is a liquid electrical conductor.  The razor blade sharpening sounds like what Keely was doing with resonating sound waves to "machine" the inside of organ pipes.
Think Legacy
Spread the Love
PulsedPower
The sand mentioned sounds very much like a type readily available on some Australian beaches, "Squeaky beach" being the most well known, I have personally walked on this sand and it has different Rheology to the more common sands, it is also almost pure white and it does squeak. Hope that helps someone.
