My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
spacetrax
one more idea... ;D
find a wrecked car driven by a diesel engine, place it on your backyard, use vegetable oil instead of diesel and replace the alternator with a more powerful generator (or not...). The car doesn?t move, so the oil consumption should be very low.
Quote from: spacetrax on February 27, 2008, 02:51:10 AM
I think I found the easiest way to create some decent power at home. If you have a regular bicycle you put the rear wheel on a device like that http://www.econvergence.net/electro.htm  and here you go! The thing is expensive, but you can weld the few pipes yourself and use an old car alternator as a generator. I guess you can make it for less than $50 .
Best,
Spacetrax
Quote from: spacetrax on February 27, 2008, 02:17:18 AM
Hi,
making enough cheap electricity for your home is not a problem, everybody can build a pedal powered generator. http://www.humboldt.edu/~ccat/pedalpower/
...and you save a lot of money by not going to gym anymore  ;)  and also stay healthy and in good shape because of everyday workout.
I?m going to do that, now I have a good reason...until today I was too lazy  :'(
Best,
Spacetrax
Quote from: helmut on February 26, 2008, 11:26:34 AM
@PYRAman
The Creator does good,to speak to you,so we can communicate all ready now.
I guess,that everyone here as members and readers are interestet to do the best,to save the planet.
But as you can see,there are many qoestions left open.
Now we have a guide to build a pyramide.
He told us,not to use black Oil anymore to save the Planet.He told us to use Vegetable Oil.
But this is a Problem .The Oil is quite expensive too,and the use brings one in trouble with
the local Goverment via tax fraud.At least in my country.
Can you ask the Creator plese some Question?
What about  HHO ,Brown Gas or any other fuel to use in car?
What about electricity? By finding a way to produce electricity cheap at home,we can switch off the
oil or gas Heater . Many of us are willing to change the supplyment of energy to get off the oil.
Thats one  reason we are here.
What about Gravity.?
Is there a save way to get Gravity in use to produce electricity?
Can we make a eart battery or cristal Power to bring us energy?
As the creator knows all the Nature,maybe he can give instruction
to us,how to build a device.
So than we can start emidiantly to save the planet.
helmut
spacetrax
Hi@all,
I?ve enlarged this picture and I?ve seen something red coming out of the cloth in the upper left corner. Are they red, or what?...
Which one af all known religions has red "gods" ?
Best,
Spacetrax
Quote from: PYRAman on February 26, 2008, 03:08:09 AM
and this is the photograph of the Creator
helmut
Quote from: spacetrax on Today at 09:51:10 AM
one more idea... Grin
End
Thats what i had all ready in mind
I have a old Diesel Engine from my Sailboat 10PS  that can drive a Generator 5KW
But the Engine will consume 2 liter oil/h  This adds to a total of 48Liters a Day
My daily need is about 10KW/ a day. Vor this i have to pay 2?uros.
Now do your own calculation.
If there is any usefull way to produce Zero Point Energy according to my personal needs and in a economic way
,i will be the first, to produce a device.
But: Until now,there is no information available to me,that matches the conditions.
So if Pyraman is able to bring such plans here,he will be my best friend.I will invite him to my home and
will try to give him a good time.
Until now his comments souds a little like, a sience fiction story.Compared to others,he shows a device,
and pics,and is doing not blame to others . Thats what i like.
And i am a friend of sience fiction.
helmut
amigo
I'm sorry but none of those ideas above are "free" energy. You have to eat nutrients in order to ride that bike, and if you are tired, sick or disabled, then no dice. Vegetable oil has to be processed and if it costs more energy to process it than it produces than it is not worth it.
Then again, even this pyramid heating is not cost effective (energy wise) if you had to invest energy through those 2x10W speakers, which had to be hooked up to an amp and a pre-amp, signal source, etc.
I am of a belief that there's no free (as in beer) energy out of the blue, therefore we must make a small investment of something to (hopefully) get a lot back. Because nature does not work on closed loops we are bound to get energy in a form that our current appliances/applications will not be compatible with. The goal should be two-fold: first we need to produce (negative) energy with a small investment from our side and collect, convert or use it.
If we wish to directly use it then the second part comes in, we need to design/create all new devices that will directly use the energy in the form we obtain it from the Nature, which means new light sources, new motors, etc. The task might be daunting but nothing is impossible, if there's a will there's a way.
PYRAman, if your friend could share with us a proof-of-principle electrical device as well as a light source and a motor that could satisfy those requirements above, that would be really helpful and practical at this point. Everything else is pointless if we are beating around the bush as many researchers are, without the "primer" on how to actually do it.
Just my 2c...
spacetrax
Hi,
I wonder how much fuel will consume the engine of my car if I let it on for a few hours. Your old diesel engine is probably not so energy efficient like the engine of a modern car, so using the very same car that you drive, for electricity generation might be a good solution.
Best,
Spacetrax
Quote from: helmut on February 27, 2008, 07:48:53 AM
End
helmut
