Thanks to ALL for your help!!
Gravity - Light
Started by libra_spirit, February 16, 2008, 04:18:14 AM
libra_spirit
http://magnetism.fateback.com/index.htm
Is Gravity "radiant light" from all matter, simply convergent at the center of mass, shifting to become a divergent force from the center as a torsion node?
Is EM radiant, or is it totally confined as light velocity energy that cannot escape a circuit?
Does Radiant Light carry a torsion field?
Is Light a scalar cancelled form having cancelled EM in balance and yet still present?
Is light EM? Can a magnet bend a beam of light?
http://magnetism.fateback.com/Gravity.htm
Is there a convergence in our future of the Spiritual and the Scientific?
Can the "Inner Light" come from a specially cut Rod?
http://magnetism.fateback.com/LightTech.htm
Is a halo Radiant Light? An aura?
Is the Light conscious?
http://magnetism.fateback.com/Specs.htm
Are conscious machines something to fear? Are they a halucination or a real phenomina?
Can emotional healing be opened by a machine that produces an energy field of Radiant Light or Gravity? A magnetic wrapped Orb? A scalar coil?
http://magnetism.fateback.com/Experiments.htm
Are Aliens real or are we creating them?
Can a conscious machine effect the weather, bring life back into a dry area?
http://magnetism.fateback.com/OZ.htm
http://magnetism.fateback.com/Tube_Device.htm
Are there coils that produce energy without any normal power sources?
http://magnetism.fateback.com/ZPE_Coils.htm
Does the earth have an energy grid system that is stronger then its weak magnetic field? A diamagnetic field grid using the oceans to propagate? Is water diamagnetic? Is diamagnetism a real force?
http://magnetism.fateback.com/EarthGrid.htm
Does the earths grid supply real power as a Radiant Light force?
http://magnetism.fateback.com/Matrix.htm
Does this force have a fractal nature, can it be subdivided to infinity?
Lots of fun theory and experiment yet to be done!
c_s_s_p Group
Kosol Group
Dave L
whatisgod
Do some research into the information below before you reject this as absurd.
I believe that I am about to send you chasing a rabbit down its hole with this, but??? Is there some type of connection between electric cosmology, what we believe is gravity, Edward Leedskalnin?s Coral Castle and ancient stone monoliths? Honestly I believe so, but it is up to you to decide. You will find that it is not as outlandish as you would first believe it to be.
Here is some info on the topics
Plasma Cosmology
Gravity is week in comparison to electromagnetic forces. A new idea on what truly drives the universe. There is more plasma out there then matter.
http://www.youtube.com/watch?v=V026kSw4XCs
Coral Castle
You just have to watch the video and attempt to figure out how this 100 lb 40 year old man that first arrived in Florida dying from pneumonia (which was incurable at the time) built this 1,100 TON stone monolith about 70 years ago with no help.
http://www.youtube.com/watch?v=amXsPcD7g5g
Coral castle code
An attempt at explaining what Edd was saying. (Im not to sure what to think about this but it is something I find of interest.)
http://www.coralcastlecode.com/
Map of ley lines / global ?power grid? nearly every ancient monolith; the pyramids the sphinx, Machu Picchu, Easter Island, obelisks around the world, Angkor Wat, The Temple of Jupiter, Stonehenge, Teotihuac?n, Nan Madol (which is just unbelievable in its self) coral castle, and literally hundreds more (nearly every monolith you can think of), sits on this geometrical grid crisscrossing the globe. Most of these sit on the intersection of these lines. All of which seem to have magnetic anomalies.
http://clipmarks.com/clipmark/DC037E37-4428-44AD-B04A-C42959BD0B13/
I don?t hold this as true science but it is difficult for me to believe that these things are not connected in some way. What is it that Einstein said ?I don?t believe in coincidence god dos not play with dice? by the way Einstein was an avid atheist.
Science answers one question and reveals a hundred more which we must then answer. It is the love of answering these innumerable questions that drives us pleasantly insane.
On a side note I believe that
light is actually a multidimensional object.
The universe is not expanding but its parts/particles are shrinking, which would appear to us (the particles) as an expansion.
I believe I have a way of visually describing and explaining the 5th dimension and how higher dimensions could be ?curled up? into the ?tiny? spaces they say it is, and still be much larger then are dimension,
but I can explain all of that later if you would like.
libra_spirit
I would love to hear your thoughts on the demension overlap model.
The latest coil I have been working with has opened a door into what I could only call another stable reality that seems to be overlapping this one. It is accessed by using a coil  of 10 feet 1 - 9/16 inches. This wire length sets up a nodal system down it. And when wound on about 1 1/4" diameter form shifts to a Radiant Light energy. Altering the diameter of the coil shifts this to a torsion field giving strong pressure. In the radiant mode the energy is very healing.
Using a mass of water in cylindrical form, as the water takes on this vibration from the coil, a doorway is opened exposing another reality parallel to this one, and the sense is that it sets at about 45 degrees to this one on a spiral curve, as though it were spining with us only slightly tilted ahead of us.
Since the light resonant lengths pulse, or generate a pulsing energy I believe this is a similiar effect to the Utron system, only completely solid state. The only moving parts are the nodes in the copper that are not fixed in distance. The pulsing rate seems to be the key to locating the other densities, and they are overlapping this one and completely fit into the same space somehow.
The nodes apearing in the iron rods are fixed distances, but in the copper they shift and create force as the geometry of the wire is altered. This is what is happening in the AG metals that is unique to them, a nuclear alignment shift of the radiant light nodes with geometry alteration. This is why Searl disc, Hamel cones, and all the devices are so subject to correct dimensions and angles. The radiant light nodes are the source of all the energy.
I am starting to believe the matrix node system is constant and all the other realities fit it exactly somehow, laying across space at other angles through the same basic nodal energy system.
Dave L
whatisgod
Ok where to start?
I will start with what science knows about the universe.
A.) There are about 12 dimensions give or take.
B.) We live in the 4th dimension
   1st is length (this is the part I have a problem with)
   2nd is a flat plain
   3rd is length width and height
   4th is space time
C.) there are laws that govern how ?things? or matter and energy act in this 4th dimension.
   1.) Nothing can move faster then light
2.) The universe is governed by the four forces; electromagnetism, gravity, the strong force, and the week force.
Now for what we know about objects in the 5th dimension
A.)   exact locations for individual objects vanish
B.)   restrictions on time such as how long it takes you to get from one place to the other vanish
C.)   The ability to ascertain the exact mass or volume of an object becomes impossible.
D.)   There are more but I don?t need to go into them at this point.
Light seems to follow every standard for a 5th dimensional object that we have.
As for the dimensional overlap concept is not an overlapping but more of a spreading out of the individual pieces of our dimension.
Expansion
The current problem with the multiple dimension concept is that somehow these other dimensions are curled up so small that we cant see them even though they are much larger then our dimension. (If that makes any scene.)
But what if this imagining of the higher dimensions is wrong?
I propose that the basic assertion of the first dimension is wrong (it left no room for anything higher then 4 dimensions) instead of a line what about a single point.
Fore example take some marbles.
The 1st dimension is one marble.
The 2nd dimension would then be a grid of marbles.
The 3rd dimension is a cube made out of marbles.
   Now consider the cube of marbles. There are small spaces in the shape of diamonds spread out within the cube. Even though we can not interact with those spaces within out dimension they do interact with 5th dimensional objects aka light. And this is what confuses scientists. It works out mathematically but we can?t see it.
My imagining of this is that our dimension is not the only marble in the cube.
Ok here we go,
Now think of colored marbles. Say our dimension is the green marbles. Next surround one marble with other marbles of slightly different colors. And now you have a small cube. Place many of those marble-cubes together and you have a much larger cube but you still have the same number of green marbles that you had before they are just simply spaced out around other marbles.
If that was difficult to follow here is a visual.
Say that our dimension is dimension e
a b c a b c a b c a b c
d e f d e f d e f  d e  f
g h I g h I g h I g  h  i
Take 9 pictures cut them up and space them out in this way and you have what I believe to be the multiverse.
I hope that this came across correctly.
libra_spirit
Your model makes more sense then the 12 dimension concept, because intuitivly we know there are only 3 spacial and one time dimension, the rest are imagination at best. The other possibility is that all are present in the same space overlapping and yet out of vibrational syncronization on the quantum level.
When you look at the devices like the Utron, having pulsing coils against a diamagnetic spining cone, and consider what Ralph Ring told us about pulsing, this looks more reasonable. Consider also the Searl disc with 90 degree pulsing magnets turning through one another in opposition. There is something very special happening with diamagnetic pulsing, and with opposing magnets pulsing copper surfaces to be noticed and taken seriously.
What no one has ever presented before is the ability to resonate the A vector potiential. This is the field perpendicular to magnetism and electric vectors. Were we have been discovering how to do this using simple linear dimensions that resonate. Shock waves always seem to manifest with this background resonance.
The only thing I would add to your model is "Spin" which is at the core of all matter as well as all energy. The realms must be in a state of spin on various levels, and the spin becomes a force [A vector potiential] that permeiates all space in all the dimensions, having a natural resonance present that all other forces work off of.]
Dave L
