Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
aether22
Quote from: gotoluc on June 26, 2008, 02:51:59 AM
Hi aether22,  if you never got the wire to self pulse on the magnet then you have not seen anyting because this whole effect is based on that. You need to pulse the positive side of the DC and if the wire sticks to the magnet then flip the magnet around or pulse the other side. Also, don't pulse the top or bottom of the magnet pulse in the center between the two poles.
Try that and let me know.
Luc
Just to clarify I should wire it up as in the diagram, the - is connected to the transformer and magnet, and the + is connected to the bouncing wire?
aether22
I managed to get oscillation though it had a tendency to stick to the magnet so I couldn't put much pressure.
it vibrated on the magnet with an audible tone, the frequency seemed too high to get much from the ignition coil (too short a time of current on), I get excellent results by holding two wires above a neo and waving one back and fourth.(large arcs)
I would note that in the first and second videos you aren't doing this auto-pulsation thing either.
I am disappointed because based on Dave's comments about it not working when current didn't pass through the magnet I was very hopeful.
Koen1
Quote from: aether22 on June 25, 2008, 11:36:04 PM
Dave mentioned that the conduction seemingly had to be through the magnet to get the effect, but I found I can get arc's with the wire not in the circuit but merely near two wires being momentarily contacted, it looks very much like it is just a case of the magnet blowing the arc out which leads to a swifter collapse and hence a greater emf.
I'm sorry but I do not find that description very clear.
Are you saying you got larger sparks without connecting the magnet to either of the electrodes,
or are you saying you managed to get sparks from a wire that was not connected to the
electrical circuit?
The first I can understand as a variation on Lucs experiment, but it sounds like you're actually
saying the last, although it is unclear to me which wire was not connected to what in the circuit...
The circuit at the neo contact point has 2 wires, right? So what's this third wire you're talkign about?
I probably just misunderstood you ;) but it's always better to ask then to start yapping about
things that were unclear to you. :)
aether22
Quote from: Koen1 on June 26, 2008, 07:30:26 AM
Yes, the largest sparks were when the wire from the transformer and the wire from the + of the battery were both held above a magnet pole (neither touching) and moved rapidly side to side, large sparks were then very easily generated. (basically the same as Teslas patent)
The same motion away from the magnet made large spikes difficult/rare/impossible.
That was all I meant.
aether22
I can get arc's with the wire magnet not in the circuit but merely near two wires being momentarily contacted
I said wire where I meant magnet.
