2 coil TPU - Appears to be OU
Started by NightBlade, February 18, 2008, 12:23:34 PM
NightBlade
Hi all, this is both my first post and first topic. As some background info im just a tinkerer with no formal training in engineering or physics aside from at the highschool level. My areas of OU research are in batteries, coils/magnet setups, and electrolosis. Im planning on expanding into plasmas, scalar technology, and pulse motors when i can afford better equipment and materials to experiment with. I have a youtube account under the handle madhacker2000 where I teach how to permanently charge batteries from other batteries. I have been in contact with plengo as his circuit seemed to mimic the effect I had produced yet he recently stated his batteries eventually ran down. Mine were charged using the 4 battery tesla switch arrangement as can be seen on http://www.panaceauniversity.org. I do not know if mine will run down as plengo's did as mine were always run in a straight loop with no circuitry at all, just a LED.
Anyway thats outside of the scope of this topic so I will move on. I recently broke down and built a simple TPU style coil today and it appears to amplify input power by 3 times. I don't have any current readings yet as my DMM's current reading appears to be shot. I obtained this meter second hand and you can see in my original youtube videos that I was using an analogue.
I wound my coil with 2 horizontally wound drivers radially wound with a collector each and wound an output radially around both of them.
In the last image you can see a small piece of twisted wire on the bottom where I joined 2 pieces of wire that were too small to wind around the 2 coils. I connected this to a ground from a power bar, the round hole (be careful lol ;D). This was crucial to the operation. I connected the 2 driver coils together and supplied 12V AC from my soundcard into them. The meter was connected to one end of the final wire and to either end of the drive coil supply. When unconnected to my computers minijack it produces around 0.3V AC and when connected it jumps to 30V AC. I tried various frequencies in a sweep but they seemed to make little difference with or without a magnet present. The standard wave coming out of my soundcard is enough to run it fine. Without the output coil lead connected my DMM shows 3.7V AC. So there can only be 3V being collected by my meter and the other 27V must be coming from my coil unless I am somehow mistaken in my readings. Please offer any suggestions or comments and happy building.  :D
EMdevices
QuoteWhen unconnected to my computers minijack it produces around 0.3V AC...
What do you mean by this?   Just the meter connected and no power input, and you are seeing a small reading of voltage?
Also,  I hope you know that voltage magnification is not OU.  A transformer does that nicely.
EM
NightBlade
Yes, when unconnected (but grounded) it produces a small voltage 0.3V. and i am aware that voltage magnification can be done with any transformer. I am not a layman, just not an expert. As I stated I cannot get reliable amperage readings with my DMM so I cannot verify an amplification of current, this is why I titled this topic "Appears to be". Im not a fool and I do not want any false hopes. I have provided all the info about how to construct this, you would make better use of your time trying it out and verifying/debunking it with empircal evidence. I just threw this together in a half an hour, even if it doesn't work this is a first stage prototype and I have much more further experimenting to do. I mearly threw this out there for others to expand and improve upon.
NightBlade
Hartiberlin made me an elite member several months ago while we were corresponding over a new petrovoltaic battery I was developing akin to John Hutchisons so I could post my findings. I eventually concluded that the power output was too small to be of any use and i've been working on coil setups since. I started this post because it seemed interesting and relevant.
Frederic2k1
Could you please make a cricuit diagram ?
Thank you
