Thanks to ALL for your help!!
2 coil TPU - Appears to be OU
Started by NightBlade, February 18, 2008, 12:23:34 PM
EMdevices
Well, if you get a 0.3 Volt signal,   you have something to work with.
I'll watch your youtube videos later from home, to see what you're doing exactly.  You might want to post a clearly labled circuit on where you take the measurements.
EM
turbo
did you happen to notice:
-Runaway self destructing situation.
-Exessive Heat production.
-Gyroscopic effect.
-Winding up and when flipped over/shut down winding down voltage.
-Etc.
M.
isfanromeo
Hi
What other electronic things you have close to it. Try to see if it works in the yard sore some were you don't have any electronic around.
All the best.
Romeo
NightBlade
@EMdevices
My videos are about tesla style battery charging and a permenent charge phenomina I came accross.
Here is the circuit diagram
Pretty unconventional I know, but this configuration just made such a larger reading on my DMM than anything else. Without a GND on the green coil it only registers 5V AC.
@Marco
-It doesn't feed power back into itself
-Feels normal temp
-doesn't appear to have much if any gyroscopic effect
-there is no magnets on it and it functions the same either way
EMdevices
thanks for the diagram Nightblade,
so if I understand correctly,  you are putting in 10V AC into the horizontal coils.    I though there was no input whatsoever into any wires having to do with the TPU.
So actually when you say "NOT CONNECTED", you mean that the last control winding, around both toroids, has one lead that is not touching anything.      (although, you are having a ground attachment somewhere along the coil)
EM
