An easy step...
Started by iacob alex, February 18, 2008, 05:11:55 PM
iacob alex
   ...for everyone,regarding their attempts to prove the validation of a possible gravity powered device,can be a different manner to test,experiment them:gravity manege.
   Usually a manege is an enclosure for training and schooling horses.But not only...
   It can be,also an animal-driven power-gear,that works on the same principle as a bicycle,an arrangement of levers and gears that transforms slow leg movement into speedy rotation of an  axle/wheel,that drives a stationary equipment.
  So,a free wheel,out of the usual bearing...the advantage can be a smaller friction and a higher sensibility when we play a tiny long arm-short arm difference.It's a peculiar  "rubbing against" motion between two bodies,
   That so old animal-manege powered mechanism can be a solution as a gravity manege style?
  Sometimes,the originality is nothing but a well-adapted imitation.
     All the Bests!  /  Alex
iacob alex
  ...as well,can be made  if we try to make a shift from a kind of flow into another.
This time from a wind stream to a gravity overflow.
We have a lot of designs for windmills,that make use of the long arm-short arm abstraction:   www.geocities.com/iacob_alex/Stellarotor.htm    ,then click on  Drafts(New Drafts) pos. 16,after that 2.
Thinking about "Momentum avalanche process...",can we  imagine a remodeling ,so to play the same abstracts,at this moment in an invisible  and irrotational cascade flow!?
Hope is a parent of faith.
Dgraphic911
menage....tiny animal....
flow, free wheel mechanism. animal powered.
yes. now the
iacob alex
.....visiting a museum of zero gravity , at :
     http://pics-about-space.com/zero-gravity-nasa-museum-houston?=1
     Sometimes , the leisure moves into inspiration...
     Al_ex
