Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
CLaNZeR
http://www.overunity.org.uk
TheOne
Hey guys, do you think this kind of magnetic toy will do the job, they are called MagneStix and they are the cheaper I found so far, 400 pieces for 25$.
http://www.magnestixtoys.com/home
They say the ball is 2/3 of the magnetix one, compared to geomag I cannot tell, anyone having experience with MagneStix?
Thanks
CLaNZeR
33 gates with new rail system
http://www.youtube.com/watch?v=Hn0CWXVw1ic
33 gates again this time Closed tope gate test as requested, which is smoother and faster but seems bigger Sticky Spot on the end.
http://uk.youtube.com/watch?v=KlhA5YECHm4
Rusty_Springs
Hi All
I just thought my attractin gate will let the roller keep going with gravity assist my repel out Trigate will let the roller comein with gravity assist so why not put the both together the Trigate at the bottom of a loop to kick a roller up and the attractin at the top to attract the same roller up, you have a airgap between both gates.
What happens if the theories right the roller goes through the bottom Trigate kicks up the hill where the attractin gate grabs it and helps it up the hill then it releases the roller just past the apex it drops down goes through the Trigate and starts the process again, I would have two rollers on the rotating arm so as one is going up the other is comming down.
Take Care All
Graham
Rusty_Springs
Hi All
I forgot to mention the smaller your Trigate is the stronger the kicking force is but that makes sence because the lines of flux are closer together the smaller it is.
Take Care All
Graham
