Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
Omnibus
@smOky2,
You should see now how one dishonest critic @modervador (applying his typical polite arrogance) is pulling the leg of @Grimer  over similar misunderstandings, let alone several others such as @Big Oil Rep, @pcstru4 and @Ice'D Bear (I haven't seen @pcstru4 and @Ice'D Bear to have been dishonest so far). They are right in this case, sorry to say.
sm0ky2
Quote from: mscoffman on March 07, 2008, 01:04:49 PM
sm0ky2;
Force is power. The time integration of power is energy. So the time integration of
force is energy.
Believe what other people observe, just don't believe their theories.
It's not a race but we are racing Mib's. They are probably changing
the material makeup of kid's toys, even as we speak. I propose we
build it out of wood to put the Mib's into the tree growing business.
Mark
Mark,
         that is basically correct, with the exception of the time propegation of the field, but to us mere humans, differences at speeds close to that of light are petty. we cant tell the difference either way.
In the context that it was used: the magnetic potential from the roller at a point outside of the field to a point just before the influence field bondary - these are two distinct points witihn the field.
between which is a magnetic potential (close to 0). as you choose points closer to the field at which to place the roller for testing - that magnetic potential increases. (pushes the roller upwards against gravity)
That long ^$#*^* 9 -page argument was over wether or not that magnetic potential at those test points was affecting the gravitational constant on the roller. (thus giving an apparent OU that was not 'real).
Rusty_Springs
Hi CLaNZeR
Yes I noticed that you can put a roller through a Trigate 6 times and 1 of those times it acts different to the other 5 so ever I have moved the Trigate or roller slightly or the magnetic field is not constant.
I just wanted to say the bottom half of the gates not the problem, it will always attract in and repel out because the flux is always going in the one direction and the roller can only follow that flux, the problem is at the top half of the Trigate there the flux is going in the opposite direction to the direction we want to travel the trick is stopping that with out cutting down on the force at the bottom half.
Its a case of I have found a way to make magnetic flux move in one direction relitive to another magnet but its not perfect so I need to find a way to make it perfect or work around it by having the roller come into the Trigate in the bridge setup later.
Take Care CLaNZeR
Graham
Rusty_Springs
Hi Gwhy
Yes thats what I have been saying the way I would have it so it comes in at the nuetral point, taking away the worry about the repel in and giving you the most repel out power.
Take Care Gway
Graham
