Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
CLaNZeR
Quote from: Rusty_Springs on March 08, 2008, 05:50:02 AM
Hi All
This is a drawing of what I ment in my last post.
Take Care All
Graham
Hi Graham
Tried removing bottom bar on the reverse setup where Tri-Force Gates were on the Rotor and Rollers on the Stator.
Part 4 below.
Hi Res:
http://www.overunity.org.uk/tri-gate/CLaNZeRSTri-ForceGate-Rotor4.wmv
YouTube version
http://www.youtube.com/watch?v=ELdY9vMIshk
Cheers
Sean.
Rusty_Springs
Hi CLaNZeR
I made a video of what I ment, I don't have a rotor setup like you so I have to do it by hand but you can see what I mean just remember the Trigates would be turned over and not moving and the roller would be on your rotor arm and moving. with this you will see I'm moving the Trigate towards the roller and the roller is attracted in then moves away from the Trigate.
I can't attach anything over  550KB's so I have to post it at http://tech.groups.yahoo.com/group/minatowheel/
Take Care  CLaNZeR
Graham
Rusty_Springs
Hi All
I forgot to mention the video is in the file section of http://tech.groups.yahoo.com/group/minatowheel/ and its name is TrigateAbove.wmv.
Take Care All
Graham
Tinker
After noon folks update on the saw gate
I got it built this morning ''KINDA'' in my Redneck fashon.
It does run for a few minutes, longest was 15 minutes on a pinky finger
nudge. It either reverses and stops or hangs on the top end with last victium [NEO] that made it past the array. It does not self start.
The good news is that It has no problem entering the array and it keeps a constant declining momentum in the array, and there is a pretty substantial push when it leaves.
I mounted the NEOS on the wheel  without securing them to the wheel   other than attraction, starting  with 2 and went up to 8, 4 5, and 6 seemed to give the best results.
I am using 1/2X1/4X1/4 N38 ring neos in the array leftover from my SMOT and the balls from the Magnetics set.
The drivers on the wheel are 1/2x1 cyl N38 NEOS.
I see some potential with this setup but I need to resolve some mechanical issues with it.
I am using the same bearings [2] that most folks were using in AL'S device on a brass axle on the wheel.
Unfortunatly it wobbels  like a Drunk Duck I need to work on the hub.
The spin isn't too shabby but the perimiter kinda looks like Fred Flintstones flat tire he as been hauling around since the '70's in his trunk.
It strikes me I [MAY!] '' have a balance issue. :0
I used stiky tape to keep the array neos lined up tacky but it worked until the wheel neos kept crashing into them cus of the wobble. Plan B is Duct tape until I can find some 2in shrink tube to keep them straight and make it easier to secure them. The arrays were spaced with 4.5 in clearance I was being conservative  that gave me more than an inch clearance if hadn't been for the wobble
Clazner you said something about raising or lowering something the array or the driver in an earlier post was working better what was it?
Accept reject or ignore
it's just information.
Be Well
Tinker
P.S. I know what time it is I went shopping ;)
sm0ky2
@ Graham
I hope this doesnt come across too offensive. i dont mean this in a bad way, but in lue of the apparent paradox. i MUST ask this question....
Are you the CEO/ corporate exec. or Own a large ammount of GeoMag stock>?????????
I have to ask, because every time this device gets more complex i find myself at the store buying more magnets........  :)  - i think i passed Clanzer up with this last batch
