Overunity Device using Magnets in the 1920's ?
Started by hansvonlieven, February 25, 2008, 10:40:31 PM
nightlife
allcanadian, I believe that anything we figure out, has already been figured out as well as patented. All we can do is make our findings public so those who want to, can build them themselves.
allcanadian
Damn, I thought I put this behind me but something Hans said got me thinking ;D
Hans said the field between the PM's is like a stream, if so then the armature is like a paddle --- we dip it in and catch hold of the stream and at the center we reverse our paddle to propel ourselves out of the stream. But the power in this instant is limited due to the surface area of our paddle and the fact work is involved when we have to turn it at the center point, as well the stream is limited in distance --- we jump from puddle to puddle incurring more losses. What we want is to extend the stream as far as possible in length to increase efficiency but still retain the geometry of the stream, why use a paddle when we could use a paddle wheel ---- think of paddles only smaller whereby energizing one catches the stream but also induces a paddle next to it in sequence, this sequence moving in the opposite direction of the stream---- so it is standing still----in the stream but the armatures are moving !!!! So there would be no switching, it would be a series of timed inductive discharges in a ring of micro armatures, micro LC circuits ------ the more slip in the armatures the more current is induced in them and the more it grabs the stream accelerating the rotor. This could be done with simple slip rings on the rotor shaft to maintain the process.
Im going to have to think on this a bit and do some calculations. :D
Charlie_V
nightlife
In this next video, think of the this coil as a voice coil and how a voice coil works and the potential it has when coupled with a crystal radio and how the voice coil could be used to create movement needed to create energy.
http://www.youtube.com/watch?v=_3ELycNRccY
Take for instance this next design of mine and alter it by replacing the battery with a crystal radio and replace the electromagnet with a voice coil. The EMF should be routed to the over all output. Also note that when the EMF is taken away, relays and coils tend to operate cooler which helps keep them as efficient as possible.
hansvonlieven
@ allcanadian,
I am not altogether convinced we are talking about the exact same thing here. Give me a day or two to think about it in depth and we'll talk some more.
I appreciate your input and contribution. I just see things a little different right now. But that is what makes bookmakers so we cannot be doing all that bad.  ;D
Greetings from the Down Underworld,
Hans von Lieven
