Overunity Device using Magnets in the 1920's ?
Started by hansvonlieven, February 25, 2008, 10:40:31 PM
Kator01
Hello all,
have a look at this Aspden-Report. It was very difficult to find because the report-section in hidden if you access the main page http://www.aspden.org :
http://www.aspden.org/reports/Es9/
an download esr9.pdf
Kator01
konduct
Quote from: Charlie_V on March 05, 2008, 06:11:26 PM
Have you actually ever tried to get a piece of metal in the exact neutral point of a magnet, let alone 4?  It is an almost, next to impossible feat.  I've tried many many times.  The best I did was using 18-8 Stainless Steel screws as positioners and "tuned" a piece of iron into the center.  This was still not perfect but pretty close.
If you have any tricks that can get around this let me know.
Thanks,
Charlie
Hi all...and Charlie...This brings up an idea and experiment I carried out. When using a ferromagnetic material for shielding, if you keep the material at exactly the magnetic center, meaning center of flux density, half way point between your two (or more) source magnets, the transition is smooth and balanced and doesn't "pinch" either of the magnets or the ferrous material. The forces maintain an equal "grip" on the material. The experiments I carried out were linear, circular arrangements are even more difficult to create a mechanism that maintains the balance. A third magnet can always be used to pull the shielding material out to fire a repulsive setup. Shielding with an attractive setup may be possible as well?
-[mag]+         [FM]         +[mag]-
         [3rdmag]
pese
Quote from: fleebell on February 25, 2008, 11:05:30 PM
  It had a 1 meg pot instead of the coil and and another ground rod instead of the antenna . We used to use the little high-z earphones you could get from radio shack with it. (those strange looking pink ones they sold)   I never could figure out how a 1 meg pot could tune it though but it did.  Learned  a lot of interesting things about the neighbors though  ;D
The rest looks like it would be easy enough to try out and see what happens.
Lee
Can not work with  Resistor.
Coil , better "tuned coil" with condensor
variable coit or variabel condensor in it.
diode as 1n34 , 1N60 gernanium diode.
or "crystal"
headphones with high impedance as 2 K-ohm.
Antenna and ground.(erath)
will work , at day with local AM station. In night also long distance reveiving possible.
G.Pese
sparks
  I was wondering if you use the aether for a magnetic flux capacitor then collapse the field in the prescense of a conductor would you get away with no backemf.  Spin up some pms over a 1000mph and see if a magnetic whirl sustains in the aether.  If so slide a conductor in and see what the shockwave produces.   I wouldn't try this at home though. ???
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
tao
Quote from: sparks on May 13, 2008, 07:18:23 PM
Hehe, in a very basic sense, the recipe for a TPU...
