The secret of a working perpetual motion gravity powered device
Started by gurangax, February 28, 2008, 12:33:16 AM
gurangax
Quote from: hansvonlieven on February 29, 2008, 08:29:27 PM
Quote from: gurangax on February 29, 2008, 05:13:56 AM
Quote from: hansvonlieven on February 29, 2008, 12:08:36 AM
Quote from: gurangax on February 28, 2008, 11:57:49 PM
Greetings to all.
Thanks to some emails now I can see things clearer. I'm not concerned anymore about the prize money. It means nothing. But like I told you guys in the previous post I don't like to give the answer directly. You must think before I give you my answer.
You have a lot to learn my boy !
Hans von Lieven
Thank you. Can you teach me?
http://keelytech.com
Hans von Lieven
hi
the link is dead, but I think I've been there before. Sorry for bothering you
gurangax
Quote from: TheOne on February 29, 2008, 06:59:54 PM
Gurangax,
The only idea that come in my mind to make the well work is the ball that go up must be as near as possible on the shaft while the other ball that come down need to be at the radius position. But I have no idea how you can do it without balancing the wheel!
Please tell us what you have found.
Hi
nice try but not the best answer.
gurangax
Quote from: P_M on February 29, 2008, 06:51:33 PM
the wheel stops, only this do not moan of the grandpa!
a quiet grandpa and a shifting wheel would be better!
"working model" is a programme, themselves he does not have this ...
joh, Malaysia ist sehr weit, schau die lieber die deutschen sachen an.
hi
If you have the time and are interested, It will be a good thing if you will model an animation of my supposed to work device after I gave the solution. Many thanks
gurangax
Quote from: hartiberlin on February 29, 2008, 05:53:07 AM
Quote from: gurangax on February 29, 2008, 04:57:45 AM
Nice try Stefan. But that's not my answer. It does have something to do with energy conservation. and easy to build. If you are in Besslers time what would you probably do. We need to think out of the box. There is an easy explanation to this.
So any one else care to try? And I do think there is a magnetic apparatus which may help but not neccessary.
-regards-
p.s I'll give the answer when I see more interested people like you here
Hi gurangax,
energy conservation ?
I can only imagine conservation of the conversion of kinetic energy ( movement of the weights)
into potential energy ( stored spring energy) and pulling the weights back up.
When you told us,
you want to get a weight out of`the wheel when it is down,
how do you get it up again afterwards ?
Do you split the weights up into smaller parts and move them up in smaller weight pieces but more in
the same time ?
Or how should this work ?
Regards, Stefan.
hi stefan
It will work as I have told you. You can explain it with standard physics. And I don't like the idea of splitting it up. I told a friend of yours about this. so I think he will tell you what I told him. Like I told you it is VERY simple.
Thanks a lot.
p.s The answer will be revealed soon. But first I need to check something else
hartiberlin
Hi Gurangax,
when will you reveal it ?
Are you somehow modifying your cylinder-masses on each side of the wheel ?
Please tell us now, how it should work. If it is not too complicated we can try to model it in
Working Model 2D simulation software and can check it, if it really will work.
If it will work, we will make sure, that you as the inventor will be soon famous and can make a lot of money by being famous.
So dont wait and post your ideas. What are you waiting for ?
Many thanks, regards, Stefan.
