Thanks to ALL for your help!!
Solid State Electric Generator
Started by helmut, February 29, 2008, 12:11:48 PM
Feynman
I think it's wonderful that we have many languages speaking.  You can use
http://babel.altavista.com
http://freetranslation.com
We can learn each other's languages. Here is a rock song from America as a greeting to friends across the oceans.  I saw this band last night.
Wir k?nnen jeder des anderen Sprachen erlernen. Ist hier ein Felsenlied von Amerika als Gru? zu den Freunden ?ber den Ozeanen. Ich sah dieses gestern.
http://youtube.com/watch?v=zauDHIfmQCQ   (live)
http://youtube.com/watch?v=-2ceQsSZpJk    (album)
@helmut
Good luck keep us updated on your experiments!
eugin_b
Quote from: helmut on March 18, 2008, 03:10:48 PM
Today i got the other Core to proseed with a new setup.
After the first rebuild endet up with no significant results,the dicision was made to
use other material and start from the beginning.
So the Question is now : more or less winding?,
equal or different diameter for the copper?
Is the most importand part  the pulser or the primery to secondary coil relation.
The goal is to sqweeze out electrons out of the secondary coil by using the
magnetic band oscillation.
At the end it should not be a overunity device but proofe
the claims that have been stated by the inventor.
I am happy for your imput
helmut
What core material was used! Use core material from nanocrystalline ferromagnet tape
As Input Power use High Frequency signal. Use Low voltage High current as Input signal!
Use Single Input Winding. Use more relations you can
You can use assimetic Input signal if you want
Put load = 10kOm to output coil
Try to add second output core as usual transformer coil for experiment
helmut
Quote from: eugin_b on March 21, 2008, 03:33:33 AM
helmut
Hello Eugin_b
Thanks for your replay
About the Core Material i can not give a presize answer.I guess,it is iron only ,perhaps ST33
It is nor strong like Steel.Today i was drilling the holes in,and after my impression,the iron was week quality.
So first i will do as you proposed.
I will make one wire inout coil with 12 windings and ~.8mm diameter.
For the secondary coil i will take the same wire.
What does the 10kohm resistor work?
helmut
eugin_b
Hello Helmut!
Quote from: helmut on March 21, 2008, 08:37:14 AM
Hello Eugin_b
helmut
Common Core Material will not work!
resistor need to see output! For successful circute you will have generator of current not voltage. Without load resistor you will have voltage = 0
According to U=IR. For I=Const & R = 0 you will have U = 0
helmut
Quote from: eugin_b on March 21, 2008, 11:15:16 AM
Hello Helmut!
Hello Eugin_b
helmut
Sorry i did not express myselve clear.
The secondary circuit must be shortet by a load.
As load i was thinking of a LED which might be near to your suggestion.
Do you think,that the core will not work?
helmut
