Single AA battery to light WHITE LED for long-long time
Started by zon, March 05, 2008, 05:18:40 AM
amigo
@ zon
I'm wondering, what is the rationale for using that BC337 in reverse, without the base connected, instead of the diode?
@ Koen1
I guess that it might be possible to replace the batteries, but you still need to have an initial jolt of power come from somewhere else (battery, solar, etc) to start the process. :)
I'm attaching a photo of my ferrite bead coils, each is a 20 turns bi-filar wound AWG 30 or 34 wire. The oscillating frequency increases from left to right.
zon
@amigo
Honestly, i don't have reason for BC337. It's only combining circuit :) where i get from "Domenico Di Mario Circuit's "  look at
http://www.geocities.com/CapeCanaveral/Lab/5185/circuit3.html#CHARGER
Where his say's "Simple electronic circuits and a hypothesis on the connection between electricity and gravity"
My background in business management, i'm just practice on bread board, measurement, and asking to all expert in this forum :)
The three words that make me to do it are "Radiance", "Resonance" and "Energy"
Feynman
lol,  way to go Zon !  you have done like Bearden says:  don't close the loop!
Btw, you should take some current readings by putting your meter in series.  =)
@amigo
Thanks for posting the pics
zon
@feynman
Measuring with BC 337
at lead  - (ground) of target battery  2.17 mA,
at lead -  (ground) of source battery 15.25 mA
Measuring with IN4148
at lead  - (ground) of target battery 5.33 mA
at lead  -  (ground) of source battery 13.56 mA
Now, I stiil monitoring on BC 337 with base lead not connected.
@Amigo
Could u give me arrangement coil,  where can i get oscilation  range 30khz - 35 khz
Could BC 549 to do that.
regards
zon
Feynman
Interesting... so positive current flow is a net loss, but the transferred potential is increasing.
I personally can see a couple of explanations.
1) what Koen mentioned, that it's coming from the 'battery potential' measurement effect, with no RE charging.
2) It's RE.  The current draw is net loss, like a Bedini motor, but there is actually RE negative energy entering the circuit  (remember that negative RE does not have current, since it flows by Dirac electron-holes.  You can only see negative energy indirectly.).
I think the only way to know for sure is to do load testing on the batteries.
@Koen
Can you think of a good load test to determine whether Zon's battery is getting charged with Bedini/Bearden-type negative RE, or whether this is a measurement artifact?
@Zon
I will replicte your circuit once I get the toroids.  I will measure frequency on the scope and give you the information I collect.
