Circular Magnetisation within Iron Wire
Started by Danny, March 05, 2008, 06:31:44 AM
hansvonlieven
G'day all,
The original article was published in 1878 in Annalen der Physik and is entitled:
Der Durchgang des galvanischen Stromes durch Eisen  Felix Auerbach 1878
You can download it from here ( Sorry it is in German )
http://www.weltderphysik.de/intern/upload/annalen_der_physik/1878/Band_241_289.pdf
Download is free.
Hans von Lieven
Danny
Quote from: hansvonlieven on March 05, 2008, 02:31:56 PM
G'day all,
Download is free.
Hans von Lieven
Excellent. Many thanks.
sparks
   Hans,
  I have come to the same findings as our German friend of 1873 I guess.  The tpu kick windings concentrate the current into the core of the collector/generator winding.  I came to this finding considering what would happen if you pull a wire through a solenoid coil instead of at right-angles to it.  I don't know if it is necessary to use a magnetic wire though.
Anyway this leaves the surface of the collector winding positively charged.  A big round copper capacitor plate. The kick windings should be wound like an automotive starter solenoid pull in coil so as to be high in self-inductance.  This will give the magnetic field it induces a vector quality.  This is how Tesla made such high voltage transformers.  He got the magnetic solenoid action going which swept across the secondary coils real fast.  In fact somewhere I have a picture of his primary winding.  It looked like a 12" coil of  1/2" copper tubing wound perfectly symetrical about 20" long.  Now we have electrons leaving the atomic orbit and experiencing velocity change.  According to both the Coriolus force and the Lorentz law a change in velocity of the electrons will result in the electrons curving in the same direction within the coil.  (This causes me to believe the magnetic effect is just inertia on a smaller scale.)  Now we are starting to windup an electron turbine.  The electric field outside of the tpu is feeling the electron low pressure zone.  Now they start to migrate towards the tpu generator winding. They will also follow the Coriolus force and start to spin around the tpu winding.  Here is where it gets sketchy for me..  The low pressure area needs to be maintained or the migration stops.  So how to get current that is spinning around the tpu generator winding into a load is my question.
   Angular momentum of the current needs to be converted to voltage somehow.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
