TPU is a self-powered current amplifier.
Started by sparks, March 09, 2008, 06:37:32 PM
sparks
     The Earth orbits the Sun at a relative velocity of 67,000 miles per hour.  In so doing it constantly traverses the magnetic field of the Sun.  Two inertial frames intersecting therefore potential energy exchange between the two. This exchange takes place not coherently but at an extremely low frequency of 8-12 hz. The sun's spin is not like the Earth's. It is different at the equator than at the poles.  So it's magnetic field is in turmoil.  Anyway the sun's magnetic field turmoil travels throughout the solar system and the Earth's magnetic field becomes pulsed at 8-12hz totally dependent on the intensity of the magnetic field of the Sun and the relative velocity of the Earth's orbit.  This is a huge amount of potential energy exchange, way more than solar heating effects of the Earth and a cloud ain't going to stop it.
     SM  always has a permanent magnet in play to start up his units.  If we take an 8hzmagnetic pulse relative to a permanent magnet and make sure a conductor is nearby a voltage will insue.  We have changed the magnetic field the conductor lies in and it will manifest a change in potential energy.  If this is done properly it will create an emf pulse in the winding at 8hz.  If the wire is a closed loop there will insue an 8hz pulse in that section of the loop that experiences the magnetic field change. And current will flow around the loop which creates it's own inertia.  Each time the pmagnet cycles we create an 8hz electomotive force inside the loop.  The energy of the 8hz pulses being stored in a vortex dc current.  Each pulse from the sun in relationship to the magnet results in increase flow of electrons in a given direction within the loop.  The loop begins to build up electrical inertia and results in a magnetic field all it's own.  It does not effect the Sun or the Earth the generators of the pulse it just keeps on sucking up inertia.  Now the vortex current is just like the pmag,  It's mag field is now in reference to the 8hz pulse directly.  This results in a further increase in vortex acceleration until the apparent velocity of the loop current reaches 1000 mile per hour.  At this relative velocity to the 8hz pulse it is in synch with the Earth's potential energy absorption from the sun's frequency.  There will be no more apparent change in the velocity of the vortex current.  The inertial concentration of the loop being equal to the Earth's inertial concentration.   We have now amplified the 8hz pulse into a current that is proportional to the amount of electrons available to be accelerated.   Now the coil vortex speed  fluctuates at 8hz.  Not it's voltage!  It's inertial frame exchanging potential energy back and forth with the Earth resulting in current velocity increase and decrease at 8hz. Lets go another stage and take some of the first loop and coil it around a much larger loop.  The first stage now taking the place of the pmag that was the initiator or receiver in the first loop.  The velocity changing through the second stage primary winding (driven by the 1st loop) starts to ramp up until it gets to 1000mph.  And there are alot of electrons moving in this coil because it's bigger.  So there is amplification of current (not voltage) all starting with our little bar magnet.  The speed of the current oscillating at 8hz. We can go omega amounts of stages with each stage getting more and more current going but each stage able to give us the full power.. Now we need to get energy out of this deal because that's why we made it. Look at how an ammeter works.  It has no idea what voltage is inside the wire just the amps and yet the needle swings.  The core current is massive and oscillating in intensity so we need a big ammeter.  We also need to make sure that when we draw current it doesn't disturb our input scource.  We need the current in the collector to be able to respond to the Earth field, not to other inertial frames created by the current draw path.   Current change to voltage change without spawning eddy currents.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
tao
Interesting theory sparks, might I ask, have you read my Macro's Dancing Magnet's thread?
If not, have a look at it please, it is not long: http://www.overunity.com/index.php/topic,2814.0.html
Question for you, relating to your theory there: Is this inertial magnification of the current in your proposed TPU design here analogous to the reason why Macro's magnets move so much more violently at 7.8Hz than at any other frequency when pulsed with the same input power?
Thanks...
Feynman
This is a really interesting analysis.  Word on the street is that Sweet's activated magnets for his vacuum triode amplifier had ELF resonance.
That is, if you put a razorblade on the activated magnets, it would oscillate back and forth indefinitely at a frequency somewhere between 4-15hz.
sparks
    @Tao
  Thankyou for the link. :)  They sure as heck resonate at 7.3.   The theory I propose comes from the understanding that magnetism is the inertial component of the observed field.   A permanent magnet is comprised of atoms whose electrons are caused to vibrate or travel in a harmonic system.  The inertia created by the charge carriers creates the magnetic effect.  You smack it with a hammer no magnetic effect.  Potential energy introduced into the inertial frame has disrupted the electronic inertia of the system.  The electrons no longer form an inertial flow and the magnetic effect goes away.  There is no majic in the permanent magnet that is able to draw energy from some unknown power.  It is just electronic inertia.   Potential energy will flow from one inertial frame to another if the relative inertia and direction are not equal.  When you speed up in a car you aren't going any faster you just have more inertia in a given direction.
   We can transfer potential energy of the Earth's inertial frame into an inertial frame we create. The potential energy will flow from the Earth frame until the created frame inertia equals the Earth's or merges into the Earth's frame.  Like a car on the highway getting pushed by a 24,ooo mile long train.
   The tpu is in resonance with the Earth due to it's orbital current relative velocity.
Speeding up a little then slowing down a little at 8Hz.
Think Legacy
Spread the Love
Koen1
Where do you get your info on the resonant frequencies of magnets?
How did you determine that frequency of exactly 7.3 Hz for example?
That Schumann resonance you begin with, the 8 to 12 Hz, is well known.
But the exact frequencies of permanent magnets depend on rather a lot
of variables and as far as I know are extremely difficult if not nearly
impossible to measure accurately, unless you have a high tech lab
with very sensitive equipment...
Plus, different types and compositions of perm magnets have different
internal (molecular) structures and their material matrices have different
characteristics, all influencing the resonant frequencies and wavepatterns
related to them...
It just seems to me that you are talking about magnets as if they are all
the same and all quite simple in structure....?
(don't get me wrong here, this is meant as constructive criticism hey ;))
