TPU is a self-powered current amplifier.
Started by sparks, March 09, 2008, 06:37:32 PM
sparks
  @Koen 1
         The magnetic field of the pms is an inertial field arising from the charge carriers movement within the mass.  It is this inertia that is recognized by Earth's magnetic field or inertial field.  Potential energy will flow at the inteface of two inertial frames.  In other words the  Earth is trying to demagnetize the pm and the pm trying to magnetize the Earth so there will be potential energy exchange.  The orbiting inertial frame of the tpu gets in the middle and the potential energy is caused to flow through it and it becomes the third magnetic or inertial frame in play now.  There need not be resonance for all this to happen just interfacing of inertial frames and the potential will flow.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Koen1
Ehm... I don't really have a problem with your relativistic potential difference
concept, that seems pretty straightforward.
But I'm still wondering where you got those frequencies...
I have yet to encounter the first permanent magnet with a
sticker on it that states its exact resonant frequency... ;)
sparks
Quote from: Koen1 on March 10, 2008, 02:11:59 PM
There is no resonance needed just an inertial frame relative to another inertial frame.  The system pulses because of the orbit of the Earth relative to the orbit of the Sun.  The sun being magnet A  The Earth magnet B  The Tpu magnet C   You can arrive at the pulse frequency by dividing the orbital momentum of the Earth's orbit by the Earth's spin  momentum.  67,ooo miles per hour orbit relative velocity/ divided by 1,000 miles per hour spin relative velocity.  6.7.  It's off from the 7.3 but it also depends what lattitude you are in and what diameter you feel the Earth ends.  MAGNETISM IS THE FOOTPRINT OF THE ELECTRICAL CHARGE CARRIERS INERTIA WITHIN THE OBSERVED FIELD.
Think Legacy
Spread the Love
Rosphere
Quote from: sparks on March 09, 2008, 06:37:32 PM
...SM  always has a permanent magnet in play to start up his units.  If we take an 8hzmagnetic pulse relative to a permanent magnet and make sure a conductor is nearby a voltage will ensue.  We have changed the magnetic field the conductor lies in and it will manifest a change in potential energy.  If this is done properly it will create an emf pulse in the winding at 8hz.  If the wire is a closed loop there will ensue an 8hz pulse in that section of the loop that experiences the magnetic field change. And current will flow around the loop which creates it's own inertia.  Each time the pmagnet cycles we create an 8hz electromotive force inside the loop.  The energy of the 8hz pulses being stored in a vortex dc current.  Each pulse from the sun in relationship to the magnet results in increase flow of electrons in a given direction within the loop.  The loop begins to build up electrical inertia and results in a magnetic field all it's own.  It does not effect the Sun or the Earth the generators of the pulse it just keeps on sucking up inertia.  Now the vortex current is just like the pmag,  It's mag field is now in reference to the 8hz pulse directly.  This results in a further increase in vortex acceleration until the apparent velocity of the loop current reaches 1000 mile per hour.  At this relative velocity to the 8hz pulse it is in synch with the Earth's potential energy absorption from the sun's frequency.  There will be no more apparent change in the velocity of the vortex current.  The inertial concentration of the loop being equal to the Earth's inertial concentration.   We have now amplified the 8hz pulse into a current that is proportional to the amount of electrons available to be accelerated.   Now the coil vortex speed  fluctuates at 8hz.  Not it's voltage!  It's inertial frame exchanging potential energy back and forth with the Earth resulting in current velocity increase and decrease at 8hz.  Lets go another stage...
@sparks,
Before I go any further, I would appreciate knowing more about this stage of the design.  It sounds as if you are stating that a very fast electrical current can be made to move about a closed loop of wire using nothing more than a permanent magnet?
If so, what experimental details would I need to demonstrate this stage?
Thank you.  :)
sparks
@Rosphere
        The magnetic field of the Earth is huge but diffuse.  You need to design the coil so that the pulse of the Earth is interfacing with the pm and not the current of the coil.  So the coil has to be wound so that when the current flows it's magnetic field is cancelled.  This allows the kicks to keep coming.  The easiest way is to use bifilar wire.
Think Legacy
Spread the Love
