Kicks explained
Started by sparks, March 16, 2008, 01:01:22 PM
aleks
Quote from: Grumpy on April 14, 2008, 02:45:19 PMPerhaps someone can tell us what is moving down the axial length of the coil being impulse driven?
Electrons and EM waves. They both produce phonons and temperature rise. Pulsing does produce much heat by itself. By the way, even if the group speed of electrons is slow (2 cm per second), they are still being bombarded by EM waves, and so they have to move through the atomic lattice "hard", be them travelling fast or slow. Phonons all the way along the axis. Disruption of atomic lattice. Non-equilibrium. This leads to DC acoustical wave known as non-hertzian wave known as scalar wave known as the comp field known as compression of aether and [probably] known as gravity force.
aleks
Quote from: sparks on April 14, 2008, 02:56:27 PMThe only energy invested so far is someone had to smack the attaching link with a sledge hammer.
Of course, it's obvious thing that control work usually requires a lot less energy than power work. However, from existing physics dogmas it is absolutely impossible to get any surplus energy from any potential-kinetic energy transformation 'tweaks'. So, if any surplus is here it must be contradicting existing physics dogmas, do not have illusions here. Any OU guys are doomed to be out-siders unless they prove multiple times that physics dogmas of the past were wrong. I do believe that coil pulsing produces field that you would call a 'sledge hammer that has little power but a powerful impact'. By the way, gravity is not a part of 'standard model', so gravity research must be lacking serious funding where as there are enough observations proving that existing physics dogmas about gravity do not represent reality good enough.
Grumpy
@aleks
Stop muckling up this thread with your BS-Pseudo-Theoretical-Star-Trek-Wanna-Be-Jargon.
        -Frank Edwards
sparks
  @ Grumpy
   I believe the use of bifilar in the kick winding coils will reduce the turn to turn capacitance and increase the turn to turn inductance.  Tesla would use bifilar and series connect 1/2 the coil to turn the whole damn coil into a capacitor.    I think the parallel connection is the way to go in this case.
If you really want direction or a rotating magnetic field effect the best way is to use a couple of frequencies and one bifilar wound kick winding.  One 1/2 of the winding pulsed at the beat and the other at the first harmonic.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
aleks
Quote from: Grumpy on April 14, 2008, 04:48:46 PM
@aleks
I knew somebody takes a role of a judge. You are obviously an Edison. He could not understand Tesla well. :)
