Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
Bruce_TPU
Quote from: spherics on March 17, 2008, 12:03:53 AM
(Snip)
Coils XYZ are pulsed at frequency F1
F1 is either the NMR frequency of FE or that frequency Divided by 3
with a phase of 120 degrees between each coil.
Coil A is fed a frequency of 3 x F1
Coil A is either fed the NMR frequency of FE or that frequency multiplied by 3
and has a phase of 0 with respect to the other coils.
In other words:
When air-core coil X pulses so does air-core coil A.
When air-core coil Y pulses so does air-core coil A.
When air-core coil Z pulses so does air-core  coil A.
The frequency should be a harmonic of the NMR of iron. Do not use iron anywhere in your device this will only cause huge eddy current problems. Iron is magnetic because of the geometry and spacing of its atoms (stationary waves remember) which interact with the ether flow in a resonant fashion despite what you may already believe! The NMR is directly linked to this geometric spacing and hence to the resonant frequency of the ether. If you pulse iron wire at iron's NMR you'll get a minor resonance effect even if the coil is not tuned to that frequency. Steven Mark was utilising this effect along with the timing delay action of iron wire to generate a rotating magnetic field of the correct frequency. The requirement for coil A to pulse in time with the other coils was not understood by SM who unwittingly incorporated its effect via interaction of several coils. A testament of observation over emperical understanding!
To complete the picture the intercept coil can be an air-core toroidal coil placed in a horizontal plane halfway between the top coil and the bottom three coils sized so that the outside of the toroid would touch, but not overlap, the imaginary planes of the tetrahedral pyramid sides. The diameter of the toroid hole should be the same as the diameter of the toroid windings for optimum results but quite frankly you could stick two solid 1 cm diameter 3/4 circle copper bars into the field and measure substantial voltage and current.
I trust you'll appreciate the risk you are now all taking. Too many of you are tempting fate by feeding the output back into the input. Consider 1000 fold output power over input. Oh yes, these are the levels you are potentially working with. 100Watt goes to 100KW. With no feedback this is a major copper vaporising experience. With feedback your momentary 100KW goes to a potential 100MW but more realistically 1MW or less as wires vaporise. How on earth do you think you and your house will survive such an event ?????????????????
I've shown enough for you to now understand with what you are playing and a schematic outline of a relatively safe design that will get you the results that you desire.
I've taken the liberty of posting whilst on vacation. Good luck.
Bruce_TPU
A couple of things that everyone should know.
SM stated, in his email response to the Bob Boyce .PDF, that it took them years to understand that they could not understand WHY it worked!  So once again, Spherics is correct.
SM stated, "That it would take a hundred years before anyone found the correct frequency."  And it would have had not Spherics given it to us.
Some of you fail to realize the momentous occasion this is.  I am stunned.  Being a skeptic is fine, but open your mind.  Let's build both Spherics version 2008 TPU and Spherics explanation for the Early TPU.
Over the many months, some have made preconception of how the TPU works, and this, for you does not fit.  I am sorry.  Our versions were always missing the two most important factors, and I have shouted it from the rooftops:  The CORRECT frequency(s) and the RMF or rotating magnetic field.
Many of us wanted the solution to be something that fit into our preconseption.  Spherics has seemingly improved on the original design and took time to understand "WHY" it works, so that such said improvement could be made.
Secret Frequency:  NMR of FE and its harmonics
SM's Early TPU:
A minimal delay in a split signal, resulting in a huge magnetic field.  I would also pulse this with a "harmonic" of the NMR of FE.  I can picture in my mind why the NMR of FE would work, but I can not yet put it into understandable words.
IMHO:  This is the real deal and the long sought after answer.
Did SM's later TPU's wire up different?  I am sure.  They learned to use the static magnetic dc bias on the control wires (Kick coils) and more collectors, etc.
Lastly, Spherics choice of "Spherics" for a user name ought to tell you something, if nothing else.  SM's company name, that we did not know until the DAY AFTER Spherics first post.  Come on guys, let's finally make something that works.
Cheers all,
Bruce
CTG Labs
Just a random thought guys... Iron is the most stable element, higher elements are trying to decay to become iron and lighter elements try to become iron from the other end of the scale.  Iron sits in the middle and all atoms desire to be iron...
Why iron is the most stable?  It has the best interaction with the Aether?  Surely no co-incidence...
D.
PS. Bruce, how many stars do you want next to your name?!
CTG Labs
aleks
Quote from: CTG Labs on March 30, 2008, 12:10:59 PM
D.
Because Earth's core is pure iron  - I've read that somewhere. Probably all we are getting is the energy from Earth's massive iron core. I mean, such massive amount of iron creates an "iron'ish" potential (and resonant) field making everything strive to become iron (since it's the lowest potential state - it's always easier to resonate together than to struggle with resonance). Well, if this fact can be used to "steal" resonant energy, that's to the better.
