Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
0 Members and 51 Guests are viewing this topic.
juice
Does it not disturb anyone else that spherics specifies 300V yet does not provide ANY dimensions whatsoever aside from (incomplete) relative dimensions? What use is 300V if you don't know what you're applying it to? Let's see I think I'll try 3 turns on my coil and apply my 300V... ZAP! WOW it exploded must be free energy..... come on now.
poynt99
vince
Duff
I logged off and it seems to work fine from my end.
Give it a try.
Vince
duff
@juice
The physical dimensions are based on the hexagonal spherical packing. The bubble or ball sizes and should be relative though there is still a lot of room for error...
Yes it bothers a lot of us. Thats probably why more have not jumped into this thread. There is much missing.
@Vince
I was finally to access your pics though I changed nothing here.
Spherics states:
     "Someone mentioned the Alberto Molina-Martinez device as being the same. It would appear at
      a casual glancing at the patent to be chock full to the brim with iron/steel and other magnetic
      materials
which I have said ad nausium is a no-no. "
You may be defeating your purpose with the steel frame.
Other than that, nice work!
I may be joining you & Keytone  if I can come to terms with the NMR frequency issue.
-Duff
Grumpy
He didn't mention a wire length - so it was probably not that important.
Since you are trying to project something out the end of the coil, I'd try a long solenoid shape with the length longer than the inner diameter which concentrates the external magnetic field at the ends - like the little white spools that wire comes on - with like 30 to 28 awg magnet wire - several hundred feet - maybe even over a thousand - so between 700 and 1500 feet - kinda depends on what the spool will hold and what looks like it will work.
As for the NMR - isn't that like 32 MHz-ish?  Wouldn't this relate to the pulse width or repetition frequency?  Probably the width as we are impact exciting the coils.  So, pulses in the nanosecond range adjusted for best effect.
and no metal supporting structure...
        -Frank Edwards
