Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
orbs
A repost with links made visible.
Quote from: orbs on April 01, 2008, 07:58:30 AM
Building on the rapid fire rat race controller, one could use a 74AHC164 with a 74VHC27 and 74AHC377 to generate same pulses as with the 4017 but with the nice symmetric delay properties of the 377. Unfortunately, 377 available as SMD only.
[Details: connect Q1..Q6 of the 164 to two NOR gates of the 27, and their output to the 2 data inputs of the 164. This creates a self-initializing shift register that rotates a 2-cycle pulse with a period of 9 cycles. Connect Q0/Q3/Q6 to the third 27 NOR and its output to E of the 377. Then connect Q1/Q4/Q7 to the data inputs of the 377. This yields the output signals for the first 3 coils. The 4th coil signal is connecting E of the 377 to one of its data inputs and the output again to an input, i.e. twice in sequence, to get the pulse delayed/shortened the same as the others. The 164 and the 377 use the same input clock signal.]
If one does use an embedded controller already, then it looks like an AD9510 clock divider is pretty good. It has 4 identical outputs (twice) that can be programmed to generate the signals for the 4 coils (one divide-by-3 with 33% duty cycle and three divide-by-9 with 11% duty cycle and 0/3/6 cycle phase shifts).
For a clock generator, the AD9912 DDS looks pretty nice, although somewhat expensive (some $70). However, it has some nice properties that make its use convenient: very high frequency output resolution and built-in comparator to generate square wave output. And the interesting part is, it is used by HAM amateur radio operators, so there are already people out there who have some experience with it. While it looks like overkill to have a device designed to generate high quality sine output to then just make it into a square wave signal, it allows very fine frequency adjustments that make it simple and flexible to use (see also AN-823 and AN-837).
Apparently it's better to use an external main clock source like the Epson Toyocom EG-2102CA PECL instead of the internal PLL of above devices. Below are some pictures taken by radio operator DL7IY from his article about the AD9912 in FA 3/08 (German magazine Funkamateur).
Spider
Pulse generator question.
I am giving the spherics a try...
Has anyone here any experience with these:
http://www.elandigitalsystems.com/usb/usbpulse100.php
The demosoftware looks nice anyways :)
Greetings Rene
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
Bruce_TPU
Quote from: EMdevices on June 30, 2008, 09:44:23 AM
Is this related in anyway?     :o
http://www.koreus.com/video/telephone-portable-mais-popcorn.html
This and other vids showing cell phones popping popcorn have been proved fraudulent.  Fox news did a special on this also.  lol   ::)   ;D
EMdevices
Shucks !!   I thought it was real   !!!  :-[  :-\
