Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
Bruce_TPU
Quote from: EMdevices on June 30, 2008, 01:12:23 PM
Shucks !!   I thought it was real   !!!  :-[  :-\
LOL  Yea, right!!   ;)
And Stanley Meyers was really poisoned.
UFO's are really aliens from another planet.
Man really came from fish, then Apes.
So as not to confuse anyone, I put the above three things into the category of phones making popcorn!   ;) :D ;D  Ha, I have stirred the pot now!
@ All
If Spherics Tetrahedral design is too difficult, try the "kick" coil with the "comp" field.  He gives a great description of how to do this, in his second post.
Those putting iron into their coils will never see a working TPU.  And the rotating magnetic field is not a "natural" effect.  It is created by 120 deg phase rotation controlled by electronics.  Check out the timing given by Spherics in his first post.  The X, Y, and Z.   Has a single person in this public forum, used an induced rotating magnetic field?  No.  No rotation, no TPU, just transformers.
Look up what SM had to say about "speed" and velocity.  Don't think linear.  Look up Tesla's "Egg of Columbus".  Look up Mark Snoswell's post in this thread.
Cheers,
Bruce
Spider
@EM,
Wooow, a Steven Mark TPU popcorn maker. Free popcorn forever !!!  ;D ;D ;D CALL NOW!!!!!
@Bruce,
Thank you!
@all
If you want to try the spherics anyways, remember........The TETRA is in the CUBE! :)
Greetings Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
Spider
Hi All,
I have not been posting much cause I have been busy.
Here is the controller I build for driving the Tetra. It uses a PIC16F648A microprocessor.
See the pics down below. Second picture is the sequence its making.
Here you can appreciate the PIC in action:
http://www.overunity.com/index.php?action=tpmod;dl=get100
It is in slow mode cause else you wouldnt see the leds switch. But this puppy can go up to 20 MHz. driving the MOSFETS :D :D
Maybe this will inspire others building too :)
Greetings Rene
poynt99
poynt99
Towards Realizing the TPU v1.2
CHAPTER 1
- Added simple table of contents to give an idea what's coming next
http://www.overunity.com/index.php?action=tpmod;dl=get110
