Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
Rosphere
Spider, what happens to the compass with the top coil in place?
Quote from: Grumpy on September 02, 2008, 05:04:13 PM...
So, the compass only spins until the field is closed on itself, then the center of the ring becomes a void and the compass stops.
wattsup
@Rosphere
My question also.
I also think the three coils should not be completely at a right angle to the toroid. It should be off by at least 10-15 degrees to initiate more spin.
Sprocket
@Spider - excellent video, I was expecting to see the compass rotating much more slowly, but that thing is really moving! :D  Is this as fast as you caould get it to spin?
Spider
Oke I did the tests.
The compass is filled with a liquid so it has a lot of drag.
If I pulse the processor clockpin with 180Hz pulses, then the compass rotation starts. At 450Hz the compass cannot follow anymore and stops or just wiggels. Topcoil makes no difference. Actual RPM of the rotating field is much lower, because it takes the processor 1 clockpuls to execute 1 line of code. 1 sequence cycle is 18 lines so rpm = pulses/18.
The frequencies and voltages are much to low to see any real RMF or vortex effects.
But its great learning and valuable for future projects
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
Peterae
