Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
sparks
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
MACEDONIA CD
HI TO ALL
  WHATT IF IS COMPASS  ROTATE WHAT THEN
THIS  NOT MEAN THAT  WHILL MAGNET FILD  ROTATE  <<NO>
WE NEED TO  ROTATE JUST ONE SEGMENT OF THE ELKTROMAGNET IN ONE DIRECTION
I SEE IS GOOD  THAT PICTURE BUT  THERE IS  NO   ELKTROMAGNET ROTATTION THERE
THE FILD IS  STUK THERE AND  IS EVERY WHERE  AUROND THE  ALL   TETRA DIVICE
IS  NOT CONCENTRATE TO ONE  DIRECTION
WHEN IS  STRAT  FIRST COIL THE FILD HAS NOT  PROPERTLY   POINTED  IS AUROND  <<AND IS NOT GIVEN  RAID  DIRECTION   FORCE  TO MAKE    SOME >
MY THINKING IS   WHEN IS STRAT ONE   LETS SAY COIL    THE FILD IS  AUROND THE  AND HE DIDNT MAKE   ANY FORCE FILD  HO WHILL BE CONCENTRATE TO  ONE POINT TO    THE     COMPASS   AND IS <<STUK THERE>
IMAGEN   IF   YOU HAVE BALL  AND YOU LIKE TO SHOT IN ONE DIRECTION    AND YOU POINT THE  ENERGY FORCE   IN  ONE  DIRECTION  OF THE BALL
IF YOU MAKE  FORCE   THE BALL   OF THE DIFERENTS POINTS AND SHOT  IN THE SAME TIME   OF  TWO PLACE OF THE SAME TIME  THE BALL  WHILL  NO MOVE
I THINK  POINT THE  <COMPASS OR   BALL   WHIT FORCE   EXSACTLY  IN ONE   DIRECTION  IF YOU WHANT TO  MOVE   OR   IF YOU DONT   POINT THE  COMPASS IS NOT ROTATE
@GIANT KILER
WHAT YOU ARE DOING AND HOW IS GOING   <<DID  YOU REALEASET THE ELKTRONES  TO MOVE   OUT OF THE    COPER> ;)
giantkiller
Quote from: MACEDONIA  CD on September 07, 2008, 06:05:52 PM
HI TO ALL
@GIANT KILER
I am labeling the green loop as copper(it makes skin turn green) or iron wire (it has the green nylon jacket). The conductor can be placed anywhere in the fields. There are 3 three coils in the picture. I will do rat shack spool test tonight.
@all,
Now here is a really big bomb.
If you look at the picture of Wardenclyffe with Nikola in it. We know that the picutre is altered. I think he is there to protray a huge answer. In that picture there are T-coils on the floor. They are are inside a huge canister like coil that runs the perimeter. Why?
He is sparking in the field!
Now we have seen multiple small examples of a frequency driven coil inside a DC biased coil haven't we?
Now lets reverse the configuration. In the Hubbard we have a moving field outside the canister like coil. I am thinking that any size drive parameter is ok. Spark gap, HV, or LV pulses of 12v @ 2amp. The last specification is what I run with most of the time. Hubbard used a distributor to channel the spark to 8 locations sequentially
--giantkiller.
Peterae
I have my controller built now, need to test it yet, i have also built the tetra frame but need to spend some time working on the coils.
Peter
Spider
Excellent build Peter,
Looking forward to your results!!!
Spider.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
