Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
wattsup
@Peterae
Nice wind. I am wondering if you could please try something that will help with my continued curiosity with all sorts of coils using the same test method. This I call the Coil Handyguy Test because it is based on his swinging device. I have made a diagram below to explain a simple test and would like to know if your coil will make voltage rise. If you have two small neomagnets and a metal shaft, a diode, a high mf cap and a voltmeter this would take about 5 minutes. You may find the result very revealing.
Elvis Oswald
Hi all.  I just found this thread today and thought I'd record my two-cents.
I had followed the thread about S.M. - and while I do believe there is a natural source of energy that can be tapped without "work" - I was convinced that S.M. was full of S.H.I.T.
However - the first post of this thread makes sense.  He just didn't know how it worked.
The description in the first post, of iron magnets, is inline with what Ed Ledskalnin said he knew about what he called individual pole magnets.  He said these monopoles ran against each other with a 'right hand twist'... that they were flowing in one pole of the earth, and out the other.
These monopoles preferred to flow through metal.
He said that the iron simply allowed this force to flow through it.  That this is the result of the alignment of the underlying structure sounds reasonable.
That steel can be magnetized by applying electricity (and realigning the underlying structure) makes sense as well.
In regards to heterodyning, anyone fine tuning in order to achieve a difference frequency that is [some significant harmonic] of the other frequencies?
giantkiller
giantkiller
Quote from: Elvis Oswald on September 14, 2008, 01:12:57 PM
welcome!
I am in process of connecting a 4 channel cntlr to 8 bifilars. 16 tanks. cntlr has other flavors also.
coils also have removable iron/
--giantkiller.
otto
Hello all,
I have to clarify something:
For me, everything except wires is a core. A strip, a donut plate........it depends only what metal(s) you use as a core.
@Grumpy
because Im using a core I HAVE success.
Otto
