Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
giantkiller
Hubbard, Searl, Coler coils are coil-centric. That is they have a copper receiver in the center. The center & perimeter coils all stand up. This vertical model cause the action on the center.
Tesla 464666(below), Marco avatar(below), T.T.Brown are horizontal models. The coils lay down. The collector/copper receiver attaches at the perimeter. The wiping or electron precession happens on the periphery. There is concentrated flux at the intersection of the coil pole and the moment of copper.
Also in the avartar there is a stick figure standing on a disk and he is holding the planet up. Kind of like Leedskalnin. He levitates and levitates a load.
The Hamel is horizontal. The magnetic pole pushes against the steel drum encasement. The magents spin is on a sine altered plane. There are 3 of these. The sine wave peaks randomly encroach upon adjacent sine planes giving a compression and decompression. He did a great job here. At high speed this device turns into a magnetic bubble. Now it is possible to see how this thing took off vertically and was never seen again. And it shut down the grid for 40 square miles. Not too difficult to understand.
http://www.keelynet.com/tesla/00464666.pdf I know it looks different and is documented different. But we know now that he puts things inside of things.
Put one or two pancake coils on the axis of this for the collector. There are even holes in the center should you decide to go mechanical at this stage. ???
The cyclical frequency has to match some precession harmonic.
--giantkiller. These are the answers I came here for.  8)
Grumpy
Hey Poynt99,
I didn't know you had updated your document:
http://www.overunity.com/index.php/topic,5486.msg126335.html#msg126335
Very nice compilation and deductions.  You view if things is not so different from my own.
So, you gonna build it?  "Substantial voltage and current" just waiting to be had.  Come on - winter is coming - you can run a heater off this thing - or Christmas lights for the entire house - chill your beer for free.
        -Frank Edwards
sparks
     @gk
   That patent is for a single phase induction motor.  Which is interesting in that it was found later that the auxillary winding could be disconnected at 3/4 full load rpm and the motor still able to run with just the main winding energised.  The stator magnetic field shifting supported by the rotating armature transformer currents.   I read a book on this subject and at the conclusion the author admitted that the magnetic circuit in this type single phase induction motor was still not fully understood.  This was after 40 or 50 pages of mathmatical formulaes chord and vector reconstructions etc.  I wasn't happy.  IMO a leg got dropped on a 3phase motor and it kept spinning and the manufacturers went on from there.
    @all
    I still fail to conceive how a rotating magnetic field is going to be observed electrically unless there is some poles set up in the flux intensity.  A motor yes a torroidal transformer?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
If you put a battery across the collector toroid, where is the magnetic field?
We are doing that in reverse - applying the magnetic field to the coil and taking out electricity.
Of course the fact that you can put two copper rods in the field and get the goods puts a twist on the simple explanation.
In brief, because a conductor is already has excess charge, an aether field moving across it will impart a force to this charge - ta-da
Coils are wound - will post a pic when I have more time.
        -Frank Edwards
MACEDONIA CD
heloo
all
zdravo prijatelju kako ide   <otto>
<marco>  yes is not important  to move  the stuff is  all  auround <pick up  some    voltage  is  free now>>
      i like TUBEs  ;) ;) ;)
