Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
giantkiller
Peterae
Slow progress on my part.
I had to make 7 coils in total.
1 coil fell apart while taking the cd sides of when wet :(
1 coil was wrong size because i used too many washers so width was wider
1 coil inductance measured incorrectly yet resistance was correct when trimmed to 740 Ohms.
The other 4 coils i used were all good matches, all 740 Ohms +/- 0.5 Ohm @ 3.025 Henrys +/- 0.005 Henrys
The resonance frequency measured by the ringing period is 5.333 Khz
All coils mounted using 1.5mm card impregnated with Laquer as glue, Alignment has been checked and is dead on.
giantkiller
Sweet! Match that up with Barbury castle crop circle.
http://www.cropcircleship.com/wiki/Barbury_Castle_Tetrahedron
And this is a mix between the NT512340 patent A and B. Could also be a galaxy.
sparks
     If we take microwaves and excite a metal to ionize air we get ourselves a plazma as one knows if he has ever nuked some chineese food and not removed the little steel handles on the takehome containers.  Now if we inject a water mist along with some seed hydrogen through this plazma we get ourselves some thunder.  The plazma depolarizes the water molecule to water molecule molecular bond and water goes to gas real fast.  This along with electrolysis of gaseous hoh and an abundance of oxygen and boom.
     Stan Meyer did this but he created his plazma flow using an ionized gas jet into the combustion chamber.  Hope that wasn't him out there in his water powered dune buggy making the crop circles. :)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Peterae
It is interesting that the crop circle swirls in a clockwise direction which for the uk is correct for water down a plug hole, i wonder if there is a similar crop circle in the southern hemisphere that swirls in the anti clockwise direction.
Looking down at Spherics layout picture coils X,Y,Z are pulsed in a fashion to fire in a anti clockwise config, so i wonder if this would alter in the nothern hemisphere as water goes down my plug hole clockwise, i am wondering if i should fire the coils the same as my water, i believe its the same for tornado's.
Peter
