Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
sparks
    Thankyou for your post cosmoLV.   Would you say then that a given coordinate on the surface of the Earth would then experience a change in the magnetic density at a rate of 1.2 to 2khz.  And how would we be able to observe or make a system relavent to this change in the magnetic field.  Perhaps the combination of two metals that respond to the changing magnetic density in different manners?
Thanks again.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
cosmoLV
instead of rod you need torus (that is main thing in that device)
any way, sample about thinking...
if we think about anti gravity - we must know, there are no anti gravity, but way to push away gravity field from something, from example some device or thing.
Keep your chakras opened :)
cosmoLV
Sorry about double post.
But, the main thing in Static generator is Ferrite (this is the main thing in ordinary radio (antenna))
Mk1
Quote from: spherics on March 17, 2008, 12:03:53 AM
http://en.wikipedia.org/wiki/Close-packing
http://cst-www.nrl.navy.mil/lattice/index.html
http://www.youtube.com/watch?v=RXO7-Lajxdg
http://www.everyscience.com/Chemistry/Inorganic/Ionic_Solids/a.1296.php
There are those amongst you that have shown courage and conviction; something that is sorely lacking in so many of the young minds of today. Can I say that you will all believe what I have to say ? Certainly not. It is a reflection of society today that so many do not question yet reject anything outside of their comfort zone. This forum is the antithesis of such dower formulaic habits. Unfortunately so many have come to associate a questioning mind as being synonimous with a disbelieving mind when in reality a questioning mind needs to be an open mind; a mind that allows the absurd, the idiotic and beyond credulous ideas to perculate into the subconscious. It is only when the full bounds of the ideas have been allowed full roam of all aspects of the mind that the varacity of the claim can be fully comprehended. All I ask is that you ponder the essence of my presentation in light of the known characteristics of the Steven Mark TPU.
I am sure many of you have already perused the given web references and have already started to believe that this posting is misplaced! Oh ye of little faith. Matter is nothing more than spherical stationary standing waves within the travelling ether! Already I hear the shutters closing. It is the ether that has the energy not the matter; it is the ether that is manipulated via torsion fields set up via electromagnetic fields; it is the ether that vortexes and is the essence of the electromagnetic field; it is the collapsing ether vortex that releases energy. The ether its self pulsates at extra-ordinary high frequency. It is this pulsing that feed energy into the spherical standing waves, that is matter, that brings about all of the characteristics of an atom.
To resonate with the ether a specific pattern is required. The spherical propogation of waves means that spherical packing dictates the precise location of electromagnet coils for optimum control. Review the files at the start of this posting. Hexagonal spherical packing (HSP) is where you need to focus. Many of you are unwittingly using face centered cubic ( FCC ) arrangement of coils. You will have limited success if your coils are placed according to FCC arrangements.
There is good reason for hexagonal packing as these scientists are beginning to comprehend.
Google the following terms to understand:  iron superconductivity hexagonal packing
All coils need to point to a central 3D location. If you look at the hexagonal packing the most basic arrangement is 4 spheres forming a tetrahedral. Place identical coils orientated so that the poles point to the dead center of the tetrahedral. You should imagine 3 spheres with one sphere on top. The top coil (coil A) will be pointing downwards and the other 3 coils (X,Y,Z) will be pointing to wards the center BUT note the three coils will not be in a horizontal plane; they will be pointing 30 degrees upwards. Now those of you on the ball will no doubt see why Bob Boyce, Marinov, GiantKiller et al. have had extraordinary results. In these designs the coils are pointing horizontal and not angled upwards, and the top vertical coil is created by wrapping around all of the three coils. As the vertical coil is not identical to the other 3 this creates problems which is why DC they feed into this coil; and the other coils need to be fed with high energy pulses. It is not optimum and neither are their results. If you set up according to hexagonal packing all coils are equidistant from each other and pointing towards a common center. You need only supply correctly phased DC offset square waves of approximately 300V (levels of 0V and 300V not -150V to 150V) to succeed in creating a rotation magnetic field which in reality is vortexing ether. Surely I don't need to tell you how to intercept a high speed rotating magnetic field to create current of high potential!
Now I'm telling you the practical theory on how to use the ether. Steven Mark never did understand exactly why things worked. His coils are not optimum but never-the-less indirectly generate what my four coils will achieve.
Coils XYZ are pulsed at frequency F1 with a phase of 120 degrees between each coil.
Coil A is fed a frequency of 3 x F1 and has a phase of 0 with respect to the other coils.
In other words:
When air-core coil X pulses so does air-core coil A.
When air-core coil Y pulses so does air-core coil A.
When air-core coil Z pulses so does air-core  coil A.
The frequency should be a harmonic of the NMR of iron. Do not use iron anywhere in your device this will only cause huge eddy current problems. Iron is magnetic because of the geometry and spacing of its atoms (stationary waves remember) which interact with the ether flow in a resonant fashion despite what you may already believe! The NMR is directly linked to this geometric spacing and hence to the resonant frequency of the ether. If you pulse iron wire at iron's NMR you'll get a minor resonance effect even if the coil is not tuned to that frequency. Steven Mark was utilising this effect along with the timing delay action of iron wire to generate a rotating magnetic field of the correct frequency. The requirement for coil A to pulse in time with the other coils was not understood by SM who unwittingly incorporated its effect via interaction of several coils. A testament of observation over emperical understanding!
To complete the picture the intercept coil can be an air-core toroidal coil placed in a horizontal plane halfway between the top coil and the bottom three coils sized so that the outside of the toroid would touch, but not overlap, the imaginary planes of the tetrahedral pyramid sides. The diameter of the toroid hole should be the same as the diameter of the toroid windings for optimum results but quite frankly you could stick two solid 1 cm diameter 3/4 circle copper bars into the field and measure substantial voltage and current.
I trust you'll appreciate the risk you are now all taking. Too many of you are tempting fate by feeding the output back into the input. Consider 1000 fold output power over input. Oh yes, these are the levels you are potentially working with. 100Watt goes to 100KW. With no feedback this is a major copper vaporising experience. With feedback your momentary 100KW goes to a potential 100MW but more realistically 1MW or less as wires vaporise. How on earth do you think you and your house will survive such an event ?????????????????
I've shown enough for you to now understand with what you are playing and a schematic outline of a relatively safe design that will get you the results that you desire.
I've taken the liberty of posting whilst on vacation. Good luck.
  Let me have a crack at explaining the high voltage reaction, i saw it from a french patent that explained it .
He called it energy from the vacuum.This is due to the copper so as electricity start pushing electron in the wire , electron move but once the electric current stops the electron moved will kickback to its previous position creating high negative sparks, to test this all need is a 9 volt battery and a large enough coil and a multimeter , i even managed to light a 120vdc neon bulb on the first try .Good coil are usually anything more than 400 turns, from hair clipper or microwave motor that principal can be recreated by any means of switching on and of power since there is such a kickback that i am not sure if very little to nothing is taken from the battery, starting the tpu with 2 magnets
most likely done with hall sensors and 2 reverse poles magnet.Hope this helps .
cosmoLV
