Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
Grumpy
Summer is coming and it is time to put the paddles across the chest of this thread...
More power, Igor!
        -Frank Edwards
Goat
Hi all
I just had a thought and before I get hit by the bus of life I want to share it with you all, it's probably the kind of TPU normal people shouldn't attempt but here goes.
I posted this in the Joule Thief thread awhile back but just had a thought on how to make it work, well possibly:
http://www.overunity.com/index.php?topic=6123.msg160207#msg160207
Instead of using a dynamo to drive the circuit what if we used a 12 DC/120 VAC with the ground as common and hot and neutral to drive Line1 and Line2 of Tesla's toroid converter?  Not sure what kind of spark gaps would be necessary to make it work but as far as the drive circuit I think a small DC/AC converter would be enough to test the theory.
Let me know what you think.
Regards,
Paul
Mannix
giantkiller
EMuntinga
hello all
i have been reading for a while now and did some rechearch and i stumbled on this
what if the device is equipted with Helmholtz Coils.
!!!!!This type of coil is used to generate a uniform magnetic field. Two coils are held parallel to each other at a distance less than their diameter . The field between the coils should be quite uniform, providing the strength of the overall field is high enough.
Helmholtz coils are commonly used for scientific tests which require controlled field conditions.
look at the helmholtz picture i have attached.
XYZ Coils
These are simply solenoids, or Helmholtz coils arranged to point in all three dimensions. They are also used for scientific tests or experiments involving controlled field conditions. Some theoretical teleportation experiments mention the use of XYZ coils for creating some kind of 'fourth dimensional' field When this field is coupled to an object and then driven at some fundamental resonant frequency, the object could be made to move in the fourth dimension. An observer would see the object disappear and then re appear in a different location.
Also picture attached.
next:
Penning Trap - Plasma Containment
A Penning trap is a set of electromagnets or coils that will create a controlled non-uniform magnetic field. The diagram on the left shows how the magnetic field is slightly less intense in the centre of the trap. This 'bubble' in the field lines is where a non neutral plasma can be contained. A non neutral plasma is simply a plasma that has an overall positive or negative charge, such as a collection of electrons. A charged 'particle' such as an electron would require an accelerating force to move it across the magnetic field lines. Without this external force the electrons in a penning trap will tend to spiral back and forth within the area of weakest field. The converging field lines at each end act like a 'magnetic mirror' allowing the plasma to remain contained .
picture plasmacontain.
Please prevent explosion of the planet.
please use a frequency generator because one of these coils amplifies the energy with a factor 250000 Volt, can let our planet explode when handled improperly and when used in combination with 220 or 110 Volt would cause a black out.
be carefull when experimenting
ernst
