Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
giantkiller
This is the final answer. The possiblities far exceed the device when altering spacetime. Now mix Helmholtz with Keely.
--giantkiller. If you're not living the dream, then you're running from the nightmare. 8)
Quote from: EMuntinga on April 18, 2009, 02:49:35 AM
hello all
i have been reading for a while now and did some rechearch and i stumbled on this
what if the device is equipted with Helmholtz Coils.
!!!!!This type of coil is used to generate a uniform magnetic field. Two coils are held parallel to each other at a distance less than their diameter . The field between the coils should be quite uniform, providing the strength of the overall field is high enough.
Helmholtz coils are commonly used for scientific tests which require controlled field conditions.
look at the helmholtz picture i have attached.
XYZ Coils
These are simply solenoids, or Helmholtz coils arranged to point in all three dimensions. They are also used for scientific tests or experiments involving controlled field conditions. Some theoretical teleportation experiments mention the use of XYZ coils for creating some kind of 'fourth dimensional' field When this field is coupled to an object and then driven at some fundamental resonant frequency, the object could be made to move in the fourth dimension. An observer would see the object disappear and then re appear in a different location.
Also picture attached.
next:
Penning Trap - Plasma Containment
A Penning trap is a set of electromagnets or coils that will create a controlled non-uniform magnetic field. The diagram on the left shows how the magnetic field is slightly less intense in the centre of the trap. This 'bubble' in the field lines is where a non neutral plasma can be contained. A non neutral plasma is simply a plasma that has an overall positive or negative charge, such as a collection of electrons. A charged 'particle' such as an electron would require an accelerating force to move it across the magnetic field lines. Without this external force the electrons in a penning trap will tend to spiral back and forth within the area of weakest field. The converging field lines at each end act like a 'magnetic mirror' allowing the plasma to remain contained .
picture plasmacontain.
Please prevent explosion of the planet.
please use a frequency generator because one of these coils amplifies the energy with a factor 250000 Volt, can let our planet explode when handled improperly and when used in combination with 220 or 110 Volt would cause a black out.
be carefull when experimenting
ernst
Grumpy
Quote from: spherics on March 24, 2008, 11:56:27 AM
It appears I have been too brief in my presentation. I truly believed that there would be a group here who would be able to make the leap between the Steven Mark devices you are familiar with and the design that I showed.
Firstly although this has been mooted I am not Jack. All I will say is the interview says more about the character of Jack than it does Steven Mark. I will also add that the SM device uses rotation. I say this without doubt and Jack is wrong in saying rotation is not necessary.
I will now talk about the Steven Mark designs you have seen in the videos and the like so you will understand why my design at the start of this message works.
The SM designs all work on the same set of principles. A pulse into a coil generates an expanding magnetic field. The magnetic field comes into being by an underlying patterning of the ether. It is a cascade action on the part of the ether that causes the EFFECT of an expanding magnetic field. If you then cause a second magnetic field to expand through the same space as the already expanding magnetic field, a specific cascading action, apattern is setup in the ether which is the EQUIVALENT of a magnetic field and has many of the characteristics of a magnetic field. By this I mean it will interact with metals, and cause the EFFECT of a current, IF the field is moving across the metal.  I will refer to this field as a COMP field from now on. But please be clear this COMP field is in addition to the expected magnetic field. This COMP field, a patterning in the ether, is dampened and effectively nulled by magnetic metals. This is why if you are using an iron core in the coils named control coils you will never get a working TPU.
No doubt this may be disconcerting to many who have fond references to baling wire, iron wire and the like. I will now digress onto the circumstance surrounding the initial eureka moment as I understand them. Audiophiles who frequent this watering-hole will no doubt have heard of QUAD ESL electrostatic speakers. An essential design element is the incoming signal is sent into, I believe, 7 or 8 progressive delay elements. These elements delay the signal by microseconds each time.
As part of experiments, associated with what would become his 3D spacial control patents, he was using these delay elements with custom made bifilar wound voice coils (i.e. air coils) and unexpectedly detected an anomolous signal on his spectrum analyser.
Steven Mark created his own delay elements using iron wire after several years of intermittent experimentation. The technique was to carefully wrap a bifilar air-coil using copper wire. The longer the length of copper the better but using identical lengths. The two coils were connected to the SAME pulse waveforms in parallel so that the magnetic field is additive NOT cancelling. The delay element was added in series to only one of the coils that made up the bifilar coil. The delay coil was made from insulated iron wire wound into an air coil. An oscilloscope was connected to both COPPER coils. The setup would be pulsed with a dc offset square wave (i.e. 0 to 20V not -10 to 10V) at the resonant frequency of the bifilar coils. The tuning consisted of cutting the iron wire down in length until an unexpected pulse/signal appeared. This pulse is the kick. I will refer to these tuned bifilar coils as kick coils.
You are privy to the information that the COMP field is nulled by iron. Those who so wish may like to take some time to fully comprehend the frustrations of closely packing the delay and bifilar coils together only to find the unexpected pulse was no longer appearing!!!  This is what SM had to contend. And Jack says SM was not technical. Bunkum!!
From traditional electrical engineering view point the kick coils for a particular quantity of energy now put out the expected magnetic field but also put out the COMP field which has effects like a magnetic field. In a world that excludes the ether, these coils are overunity. If the world took into account the ether, then the coils would not be thought of as overunity.
The magnetic field is now larger than expected. All that needs to be done is to rotate this field in a circle and intercept the field with an output coil. The captured energy is greater than the input energy because of the energy apparently created by the COMP field. If you arrange all N poles of the kicker coils so that they point towards the center and pulse each coil in turn you will get a rotating magnetic field. There are many ways to create a rotating magnetic field. A secondary effect of a rotating field is the entrainment of the COMP field so that the pattern in the ether is partially additive. A big problem was the iron in the delay coils. It was found that a large solenoid fed with a DC current to produce a static magnetic field around all of the kicker coils allowed the kicker coils to be tuned with the iron delay coils in close proximity.
Intercepting only N poles of the kicker coils means you get a DC output along with a smaller induced ripple from pulsing the kicker coils.
Feedback of the output into the input was achieved using toroidal saturable inductor switches. I've copied the picture from other messages of the inductor switches. Refer to the patent for an example to see how these switches are used. Early designs used a small magnet to bias the saturable inductors.
All SM devices had small batteries to power the LC oscillators. The LC oscillators were used as control pulse currents to the saturable inductors. To start the process high voltage capacitors were step charged, this is why the coils took time to start-up! The first few pulses came from these pre-charged capacitors being switched via saturable inductors. Part of the DC output was feedback to keep the capacitors fully charged.
My design shown at the very start of this message thread eliminated the need for an iron delay coil because the pattern is set up in the ether outside of the influence of copper metal of the control coils. It directly allows the COMP field to be generated IN FREE SPACE. By placing the output toroidal coil within this free space the COMP field is intercepted. The complete lack of any magnetic materials within this design is what allows this to happen.
I do believe there are elements of information here that you will not have been aware of before. I trust this is enough to convince at least some of you to reflect and ponder more seriously on this material.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19820016542_1982016542.pdf
I believe the COMP Field is a "companion field":
http://www.bibhasde.com/veipaper.pdf
http://www.bibhasde.com/compwavepaper.pdf
I'll leave interpretations and conclusions to the reader.
EDIT:
This effect was mentioned on ZPEnergy back in 2004 as a possible explanation for Sweet's VTA, and is mentioned in several astrophysical texts.
I doubt that the author has heard of the TPU, or has put any possible power generation aspect into the public domain.
He does have a great deal of work performed after these papers on his web site, some of it confirms the threory outlined in these two papers.
        -Frank Edwards
ronotte
@Grumpy,
your correlation of Spherics COMP field and the 1992 B R De (Dept Energy-California) may be really correct. The researcher anyway reported only a theoretical approach concluding that the 'Companion wave' could be used to carry additional BW for data. In reality they tested only heir assumptions by trying to measure a by broduct of this EM: a physical dipole antenna mechanical momentum. For example it remains unclear if said mechanical displacement really due to Companion wave action!
The analogy with Spherics text is incredible...but the so well described COMP field I have not seen.
In Spherics 3D device that I built and fully tested, the CCU coils are almost touching. This means that pulsing a CCU I found on the adjacent CCUs very big signals (copia of the pulsed one). Well, but no power at all on collector......so no COMP field generated ...and no interaction with copper. No way even to measure any mechanical displacement.
I do not know how to setup that comp field. An idea could be that to pulse in sequence a number of coils 'one almost over the previous' using HV ns pulse and according very high repetition rate. Of course the coil being of low inductance and arranged in a toroidal former.
ronotte
Grumpy
Quote from: ronotte on October 01, 2009, 12:32:50 PM
@Grumpy,
ronotte
Hello Roberto,
The author has performed addtional test and written additional papers regarding the companion field since this time (1992).  He states on his web site that the CFA (cross field antenna) verifies the existence of the companion field.
After reading a few of his articles, I noticed that what he described sounded more and more like William Hooper's "Motional Electric Field" and I believe they are the same thing.  If you comapre the two, you will see striking similarities and many identical properties.
How to see it?  I am not so good at it - yet.  Sometimes it scares you.  I started with spark gaps and they work, but are erratic.  Vacuum triggered gaps will probably work very well, as will avalanche stacks, and saturable reactors.  Triode and other valve tubes too, as you will not need a high rep rate.  If it is there, you will see it with one pulse.  This won't charge a cap or battery, but it will effect it.
Start with just one coil and use the highest voltage that you can work with and a fast rise at the switch.  How fast of a rise?  As fast as you can make it.  The fastest switch is worthless without the shockwave, so look at the path that the energy takes from the switch.  You want it be very fast and then BAM! it hits the coil.  You are working with a wave that moves along a wire - not electrons!  Why match the load?  How much energy just missed the coil?  This is no normal load!  This is a mass that is going to be hit with a hammer and ring like a bell.  You do not want to reflect the pulse back to the switch.  You want to release it into space as radiated waves of changing density.  The switch is open when the energy slams into the coil.  The traveling wave of your pulse has a big problem now.  It has a big polarization current the cannot go into the wire as the wire is open.  This current is not from electrons - it can not dissipate as heat.   It can not stay around the wire. What is it to do?
To not create the shockwave would be a violation of "conservation of energy".
Use a neon power supply - not a microwave oven transformer.
As far as I could uncover, Joseph Henry was the first to encounter it and document it when he discharged Leyden Jars into a coil to magnetize needle / nails and found that he had magnetized nails two floors below his lab.  So, a cap, coil, and switch will work.  Keep in mind that the event did not always occur for Henry.
        -Frank Edwards
darkspeed
Quote from: Grumpy on October 01, 2009, 04:10:53 PM
Hello Roberto,
Good info Grumpy! Just wanted to add.. as far as I know ... once you get the pulse procedure down.. the pulses are additive.. so it may take a while for full achievable power to spool up
